-   -   Ajusting CR on 2.5 conversion (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1044772-ajusting-cr-2-5-conversion.html)
Anglocanadian 11-19-2019 07:38 PM
Seems like the "spacer" solutions been around for a while and i thought I had come up with something new !
The deck height must have been borderline with those heads if you had to use a spacer ?
faapgar 11-20-2019 05:58 AM
Supertec 2.5
Henry,I like the head treatment on the 2.5.Very slick.Keeps the charge in the center for better flow.
Henry Schmidt 11-20-2019 08:46 AM
Our big concern was flow around the valves (valve shrouding). Our thinking was smaller valves or high lift cams. Next time around I believe we will polish the chamber to improve flow....if there is a next time.
In this instance we went with high lift cams. @ 490 intake lift the heads flowed better than expected. Bill @ Extreme was surprised at the flow with all things considered.
jm993rs 11-26-2019 05:46 AM
Very very interesant .....:mad::eek::eek:
r lane 12-03-2019 12:09 PM
I suppose at some point you can have too small of a chamber that will not accommodate the air and fuel charge available. Don't know what issues would materialize from that condition, cavitation, scrambled fuel mixture? Anyone have a base formula for calculating optimum cylinder head volume based on overall displacement. Obviously other factors have to be considered, but a base number.
r lane 12-03-2019 12:15 PM
I wrote prior to thinking. Your desired compression ratio will determine that relationship.
911pcars 12-03-2019 12:40 PM
High compression ratios as a result of piston or combustion chamber shape is beneficial for both power and fuel mileage - up to a point, as long as moving parts don't collide and/or detonation isn't the result. Fuel octane, ignition advance settings, altitude, ambient air temperatures and operating conditions are variables that will greatly affect engine longevity. Pay attention to those conditions.
As a rough estimate, depending on the above plus the physical engine specs, compression ratios approaching/in the range of/exceeding 10:1 may/will require twin plug ignition or other strategies to mitigate destructive detonation.
Some ATF, 1/4" sheet plastic, a graduated burette, an assembled cylinder head and a calculator can be used to calculate the physical CR.
http://forums.pelicanparts.com/uploa...1575405381.jpg
https://www.google.com/search?q=measure+compression+ratio&client=firefox-b-1-ab&sxsrf=ACYBGNTZVuVcyy39xKIr6Kc99WS2UzWoBA:157540 5485933&source=lnms&sa=X&ved=0ahUKEwimxPbiqprmAhVD rZ4KHb7yDh4Q_AUIDCgA&biw=1076&bih=674&dpr=2.22
Sherwood
Walt Fricke 12-04-2019 11:36 AM
I have just mocked up one piston/cylinder/head, run the piston to TDC, measured what the VTDC is directly by filling the chamber through the spark plug hole (engine on stand appropriately tilted, and a modified spark plug with a clear plastic tube with an X extra CC mark on it, as a filler funnel). It is a quick and dirty, and probably not the way to CC every hole to get that super exact match. But seems to work - the MMO didn't leak by the rings. I've not compared the result to that achieved in the usual way, but I can't see why it would be off.
Anglocanadian 12-07-2019 09:29 AM
I did mine in the same way through the plug hole, the C/R is in the low 8's and the deck height 1mm . I figure that's about as good as it gets without going "super modified" as Henry has done.
I am using the QSC iron barrels and pistons as the engine is a low budget Sunday afternoon cruiser not a track day car.
