Rocker Arm OEM?
I am rebuilding a 76 2.7 motor. 3 of the rocker arms have pitting. I have another set but they don't have the markers in the castings. In the attached picture the bottom/right set have marking cast in the arms and the ones at the top/left don't. Can I use the set without the markings? Were there multiple OEM providers of rocker arms?
George 74 911 Racer 08 Spec Cayman Racer 76 914 Cruiser |
Yes, there are several different suppliers of rockers over the years..
Bruce |
You may want to have them reconditioned as the bushings can have wear as well as the foot. Elgin Cams does a nice job. Bob
Try not, Do or Do not
We do a pretty nice job of reconditioning rocker as well.
Rocker process: We remove the old bushing and adjuster (if present) Clean adjuster threads with 8x1.0 forming tap. Ream the bushing hole Black Oxide the rocker Press in the new DP-4 bushing and burnish Surface the contact pad Coat the contact pad with Moly dry film (TLML 2) Treat the rocker to a Cryogenic conversion process
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Henry, those look good enough to eat. John
Thanks for the input.
