-   -   Engine rebuilser's quiz topic (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1046226-engine-rebuilsers-quiz-topic.html)
911heaven 11-28-2019 05:06 AM
You do multiple leak down tests, but can't get consistent readings of those numbers. Wherein lies the problem? Is it a bent valve? What could you say off the top of your head?
bernie
dannobee 11-28-2019 06:26 AM
Listen to where the air is leaking.
Henry Schmidt 11-28-2019 10:16 AM
Carbon from the spark plug contaminating the exhaust seat.
Try tapping on the exhaust rocker.
Or possibly the cylinder off tdc.
911heaven 11-30-2019 12:32 AM
Thank you Dannobe and Henry! We've already strrpped it down for a fresh top end job in process. So far it looks like it needed it, so thanks again. Shouldn't be any problem once this is completed.
