Jeff Alton's Avatar
Promised the 3.8 dyno graph, here it is...
Hinted a few times in recent threads we posted about the 3.8 we were building. Here is the dyno plot. Very pleased. Notes about the build are in the chart...
Cheers
www.turn3autosport.com
Old 11-28-2019, 09:02 PM
flat6pilot's Avatar
Impressive numbers, Jeff! Were there pics of the engine I missed? What's this going in?
Kyle
1980 911sc 3.2 Turbo, 930 Trans
2006 BMW 330i 6mt (DD)
Old 11-28-2019, 11:17 PM
Wow Jeff! Love the flat torque curve!
Question about the ported Heads: Were only intakes ported or did you also remove exhaust ceramic liners?
Track: 91 C2 SuperCup wannabe, 08 Cayman S
Street: 85 RUF BTR Slant-nose, 70 911 T Coupe Pastel Blue
Projects: 82 911 SC 3.6, 72 911 T Coupe, 74 914 Signal Orange
Old 11-29-2019, 07:08 AM
Jeff Alton's Avatar
^^^ Ported was perhaps not the correct word. Blending of the guide boss and general clean up would have been more accurate. Liners are still in place.
Engine is in a 964.
In the pics you can see our 100% CF RS Style heater fan bypass tube made specifically to clear the ITBs. This tube is part of our Turn3 Autosport 100% Carbon line of products.
Cheers
Old 11-29-2019, 10:07 PM
JoeMag's Avatar
What compression ratio?
Old 12-06-2019, 01:20 PM
It's a 914 ...
stownsen914's Avatar
Impressive numbers, especially for a streetable motor! It looks like hp is still climbing at 6500 when the graph stops?
Old 12-07-2019, 05:28 AM
I have always thought the more important number is the HP per $ and HP per LB, I think that is a great way to measure engines value/performance.
Either way this is a sick engine, that i'm sure it twice the cost of my entire 911 lol
Old 12-07-2019, 07:40 AM
Jeff Alton's Avatar
^^^ This motor is not inexpensive. At some point the HP/$$ value starts to change. You can get a few HP for a few $$. A few more HP for a few more $$.
To get the sort of HP/Tq this motor makes it does cost. But, this motor (like all of our custom builds) is built with all of the best components. It costs between 40-65% of what some in the industry will charge, even though they largely use the same components. I would put the driveability of this motor (and all of the custom HP motors we build) up against any similar build and not be worried at all... Our low dollar helps keep the retail cost of the build down as well.
Cheers
Old 12-07-2019, 09:07 PM
I want one.
Old 12-07-2019, 11:11 PM
What lobe centers on the cam did you select and what compression ratio did you end up with on the 3.8
Old 12-14-2019, 01:14 PM
Jeff Alton's Avatar
11.5:1 DR. Lobe centers are 113*.
Old 12-14-2019, 02:34 PM
Thanks Jeff
Curious, are you running pump gas and if so, what obtained?
JA
Old 12-14-2019, 02:41 PM
Octane?
Old 12-14-2019, 02:42 PM
Jeff Alton's Avatar
91 Pump up here. However, here in BC we have a special blend of "low carbon" fuel which does effect power ratings. Many around here have proven using 92 from WA state will create a very noticeable bump in power on the dyno.
Cheers
Old 12-14-2019, 10:50 PM
Gawd, I didn’t realize you guys had worse fuel up there than us. Amazes me that a lawn mower would run let alone a H.P. Porsche motor.
Super nice build btw. You must be happy with that torque curve. Or lack there of. Pretty darn flat.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 12-31-2019, 07:58 PM
Racer
winders's Avatar
What size are the ITBs?
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 12-31-2019, 11:18 PM
What cams are you running? I am impressed by the flat upper torque curve. I’ve seen similar with VRAM but never thought you’d get there with ITB’s.
Old 01-01-2020, 02:52 AM
Jeff Alton's Avatar
Cams are a DC24. We chose these after consulting with John (which we have been for years) to get a big wide torque curve/plateau. With all of these motors we want the throttle response and power the ITBs can make. But we want to chose a cam that doesn't make the motor a more typical ITB motor in terms of its power delivery. Cam choice, CR, displacement, exhaust all play into it. Then having an amazing tuning partner that can make the motor produce as much power as it can in all load/dynamic situations is key for us. Could we build a peaky version with higher HP? Sure, but that would not fit the requirements of this client.
Cheers
Old 01-01-2020, 11:22 PM
Jeff Alton's Avatar
51mm tapered
Old 01-01-2020, 11:27 PM
3rd_gear_Ted's Avatar
Just curious, what cooling set up gets rid of all the BTU's that +400 HP creates for the engine and tranny.
1980 911 - Metzger 3.6L
2016 Cayman S
Old 01-04-2020, 01:20 PM
