3.8 cayman
Although most of the is forum is dedicated to aircooled motors, here is a change of pace!
3.8 conversion on a 987.1 Cayman S. LN engineering sleeves, JE pistons, Schrick cams, IPD intake plenum, ECU tune and complete exhaust including catless headers... Here is where it is at so far! ![]() ![]() ![]() And the reason it came apart in the first place... ![]() Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
unhappy looking pistons...
The scoring of the bores and pistons is becoming more and more common on M96/97 engines. The current theory is that the piston expands quicker than the block during a cold start and their is not enough clearance to accommodate this...
Cherers
Racer
And what are the symptoms?
Preston Brown Street: 2009 911 Carrera S Coupe | 2015 Cayenne S | 1995 Audi ÜrS6 (unicorn) 1965 356 C Coupe | 2010 F250 (support vehicle) Race: 1994 964 GT2/1 | Various 944s | 2016 Superlite SLC | 2007 997 Carrera |
You will see increased oil consumption and begin to hear a ticking sound similar to a failing lifter. The ticking and oil consumption will get worse as the scoring continues to develop.
How did this build turn out? I'm specing out a very similar 3.8 conversion and was considering Schrick cams. Finding feedback or performance results on these cams by anyone has proven hard to come by. What HP/TQ did you get, swap in all new lifters, anything else?
Any feedback greatly appreciated. |
