2.4 Engine to ST Speces
Hello guys,
I need your knowledge to budget my 2.4 engine to ST specs. The car is a 1972 911T with a ST body, the engine is a stock engine but I will like to converted to an ST spec. Plesase let me know a ball park for this kind of engine build. Thank you. |
I am going to say $15-20K if you do it yourself. I am selling a MFI 2,4 I built with S pistons and E cams. I totaled up the parts and machine work and had $11K+ in cost and am sure I did not total up everything. My case was in pretty good shape and did not need to be narrowed and re-bored (more cost) That price doesn't include any cost for assembly, cleaning making stuff look nice etc. If you keep the MFI You will also need to have additional MFI work done, probably another $4K. Pricing estimates below.
Link to another thread with similar question. 1973 2.4T Engine Rebuild DIY Cost inserts 390 oil bypass 175 deck 150 line hone 200 crank 200 rods 420 valve job 420 valves 300 surface 220 valve guides 100 rockers 500 P&C 3500 tensionor kit 890 sc oil pump 250 chains 100 sprockets 300 idlers 627 e cams 1000 rod bearings 275 rod bolts 130 main bearings 130 gasket set 220 john |
Thank you so much Targa72e. I have a better idea to make the budget.
Banned
The car is a 1972 911T with a ST body xender discord omegle , the engine is a stock engine but I will like to converted to an ST spec.
Under the radar
ADMIN, Have you seen this post? ^
