The torque number is reasonable for flywheel, a bit high for rear wheel. Maybe that dyno is already corrected for drivetrain loss.
Sent from my Nokia 7.1 using Tapatalk |
Thanks all for your insightful input. A quick update, my cylinders are with EBS for replating and honing. I've also decided to opt for a set of new CP pistons in 11:5:1 CR which will open up cam choice a bit. My goal is still to keep this motor rather mild to help elongate the life span of my 915 so cams will land somewhere in the DC24 range.
11.5 ? thats a lot is it not ? How will you avoid detonation ?
Maybe you missed the point. The point is that your 11.5:1 engine has a lot more compression than a standard 3.6 as delivered. So, if you are running pump gas, it would be good if your EFI system has knock sensors and can retard the timing.
My race engine with about the same compression ratio and probably 25 degrees of advance needs 100 octane race gas to be safe. So be careful!
I'm building this exact same setup and I'm hoping for 270 WHP. That would be a nice 90hp jump over my RoW 3.0 that dyno'd at 180 whp. I was recommended and went with 95 3.6 with Rasant ITB's/ GT3 Plenum DC 21 cams and AEM Stand Alone.
| All times are GMT -8. The time now is 11:26 AM. |
