Gap between newly installed engine and new tin gasket
I just finished installing my rebuilt engine in my 1982 SC. While the engine was out, I installed new engine compartment tin gaskets. After getting the engine installed, there’s about a 1” gap between the engine tins and gasket. The long side of the gasket has 2 flaps - does one go above and one below the tins? I can work some of the gasket to do that, but it just pops upward. Suggestions?
Old 02-02-2020, 05:57 PM
here's a picture
Paul
1982 911SC
Old 02-02-2020, 07:02 PM
PRO Motorsports
Tyson Schmidt's Avatar
Yes,you have to pull the lower flap down all around the perimeter.
You can sometimes do it with you fingers and may need to use a tool to help if it’s a tight fit.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 02-02-2020, 10:43 PM
