opinions on this engine local to me?
this popped up on my local facebook. I've considered buying it for future rebuild and install into my flared 74 914. Appears to be a 911T engine.
https://www.facebook.com/marketplace/item/2674783612589753/ value as a core? how easy/expensive would it be to rebuild as E or S specs? sorry for the newb questions. Not that familiar with 911 six engines
2002 Porsche 911 turbo 2007 Porsche Cayman S track car 1987 Porsche 924 Carrera GT tribute 2015 BMW X5 |
70 T engine so no oil squirters for pistons. Mag case so if it needs the works figure on 15K if you build it your self. I listed some pricing for my 2.4 build in this post, also good price estimates from others.
2.4 Engine to ST Speces john |
Under the radar
Without a running history, it might be worth half what is being asked just in parts.
I would do a leakdown and bore scope inspection, at the very least, if I was interested in this motor. If you are not experienced with these motors, and expect someone else to do the wrenching, you will probably be in for a big surprise.
Thanks for the input. I decided to pass on it for now.
I’m learning about the costs of 6 cyl engines |
Better off to start with a 3.0
Residual value is higher and build costs tend to be less Hate to see anyone with $15000+ in a 2.2 Bruce |
gearhead
3l offers all kinds of clutch and gearbox strength issues on a 914. Better to stick with the 2.2-2.7l engines for a -6 conversion unless one is also doing a 915/916 gearbox conversion at the same time.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
