Nux Nux is offline
Nux's Avatar
New cast iron cylinders for 2.7 rebuild?
I'm rebuilding a 2.7.
Bad leakdown and excessive oil consumption.
Turns out, it has badly worn alusil cylinders.
So I've looked for replacements and found a package from Design911 (England) consisting of 90mm cast iron cylinders with JE pistons 9.5cr. No CE gasket on top of cylinders.
What is your opinion on that? Price is very good indeed, about 2500$ for at p/c set. They also do a slip-fit 92mm for a 2.8 big bore. Same price.
Old 02-09-2020, 05:49 AM
The cast iron cylinders work fine but IMO a CE ring groove should be machined. Measure everything of course.
No physical quantity completely explains its own existence
Old 02-09-2020, 06:45 AM
It sounds like they are QSC cylinders which come without CE ring grooves.
I'm currently using the same 90mm,s for my 2.5 , I'm lucky in having the use of a lathe and was able to add them. I actually contacted QSC for there opinion on this and did not get a reply.
Old 02-09-2020, 07:00 AM
You can have them Nikasiled.
Old 02-09-2020, 10:55 AM
Think before writing. I am not sure whether the pistons for Alusil are compatible with Nikasil cylinders, and I may have this issue confused with mixing KS with Mahle. Sorry for the runaround. Bob
Old 02-09-2020, 10:59 AM
Nux Nux is offline
Nux's Avatar
Haha - well I didn't really think about that. Might actually be a viable option with new JE pistons.
But then again, with the other option we can go 2.8 for the same price.
Old 02-09-2020, 11:23 AM
Nux Nux is offline
Nux's Avatar
You're probably right. They're called 'retro performance' at Design911.
I was wrong about the price, it's only 2000$ for a complete set.
Old 02-09-2020, 11:30 AM
My thinking was I will only be using the car for cruising on sunny days so why go to the expense of building a competition engine !
Old 02-09-2020, 12:12 PM
targa72e's Avatar
Why not sent your Alusil cylinders out to be coated with Nickasil. You would need new pistons from JE or CP but you could pick what you want. Nickasil will wear better than cast iron and Aluminum has better cooling. EBS does these on an exchange basis.
john
Old 02-09-2020, 12:45 PM
Under the radar
Trackrash's Avatar
john
And while you are at it have them bored to 92. Might be worth the extra $$.
Gordon
'71 911 Coupe 3,0L outlawed
Old 02-09-2020, 01:27 PM
Nux Nux is offline
Nux's Avatar
john
Thats my current plan. Cost is about the same, but I get nikasil and a CE gasket. Win-win.
Add JE 9.5cr pistons and this should be a happy little engine again.
Old 02-10-2020, 01:36 PM
