Strange CIS banjo fitting
working on my cis system out of a 3.0l 76 row turbo .. i removed all the banjo fitting a week ago to soak and clean them .. while i was inspecting the parts last night i noticed two of the banjo fittings were different than the rest. They look to have plastic restrictors in them and i have no idea where they go .. any help would be greatly appreciated
Regards Ned ![]() ![]()
They are check valve banjos they probably go to the fuel distributor area.
But then I don’t remember them from my 76 turbo Bruce |
Look closely and see if they're not screens instead of check valves.
No screens just a little plastic plug that rattles back and forth . when you shake it. i don't see how these can work as a check valve there is no spring behind them .
The 9 Store
Ask Boy911SC / Tony
All used parts sold as is. |
