widebody back spacing offset confusion
ok so i've read plenty of confusing threads regarding backspacing offsets et - and + and spacers and have seen many pictures of great looking cars and wheels that simply state the wheel sizes with no rim offsets sizes . now im super confused but i believe i moving in the right direction to acquire a set of deep dish wheels with little to no spacers for my 80 sc steel widebody car with sc trailing arms and turbo front and rear fenders.
... i am currently looking to order a set of braid 17x9/11
from what i understand 9s with a +3 and the 11s with a -21 should fit under my 80 wide body conversion ( assuming the conversion was done correctly and it does appear to be done correctly)... from what i understand from the offset chart. The +3 on the 9s and the -21 on the 11s should give me a 5 1/8" offset /backspace on the rims . giving me the option to adjust the stance a little out with up to a 1/4" spacer if needed.
so after reading a lot about offsets and backspacing and looking at offset charts and diagrams i am a little confused . according to the pictures A zero offset on a 9 inch rim splits the rim right down the middle giving a 4.5" in the front and 4.5" in the back .. but if you look at the chart a 0 offset has a 5" backspacing and 4 inch front spacing from center line .. ( what am i missing ???) there appears to be a 1/2 inch variance on all the offsets ..
i would love to hear from someone who is running 9s with an et offset between -3 and +3 and 11s between a -21 and -27 wondering about rubbing, spacers, no spacers and what tires you are using and a picture would be great ..
Thanks in advance
Regards Ned
Old 03-06-2020, 09:00 AM
wayner's Avatar
please share your widebody rim,tire,and fender specs and pics...drool
17" Wheel Build - how wide should I go?
need help - tire sizes for wide body
SOLD - 914 wide body hot rod
Old 03-06-2020, 10:13 AM
wayner's Avatar
Regards Ned
Not for the centre but from the mounting surface. The variance you are seeing may be the hub thickness of the wheel
Also, ook at tire sizes. I went with 275 rear tire and a 10.5 rear rim since an 11 is too wide for a 275 and that tire was more widely available.
Essentially take your stock rim and add all of the additional width to the front side
(You can squeak a bit more out of the backside if needed as you can see in some of the threads)
Old 03-06-2020, 10:17 AM
all good reads there are probably 50 other older threads all the same showing tire sizes . but none address what offsets are used and whether spacers were used . would love to hear from someone who used a 11x17 -21 to -27 et on a widebody .
Old 03-06-2020, 11:01 AM
