project Weber Carbuerators Into 1973.5 CIS Engine
I am going to put Weber Carbs on my 2.4 CIS motor... (please do not try to tell me how great CIS is ... (it is out) Except the ALUMINUM COLLARS that the injectors and rubber Was in.... There in is the problem!! Can anybody tell me how they removed the ALUMINUM COLLARS and how You PLUGGED the hole ?????? At this point I have not taken the engine from the car, nor have I removed the heads off of the engine...(which I am sure will bring disparaging remarks) Help from someone WHO HAS DONE this will be truly appreciated... Thank You in advance !!!!!!
Old 03-09-2020, 04:39 PM
HarryD's Avatar
Cross posted in 911 Forum.
Originally Posted by jyporscheboy View Post
I am considering putting 40IDA Weber carbs on my 1973.5 911T .. Anybody have experience in this project .. Any help or suggestions will be greatly appreciated ..
You have been looking at this conversion since 2011. Why the extended delay?
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 03-09-2020, 05:50 PM
targa72e's Avatar
HI,
I just removed the plugs a couple weeks ago but have not plugged the holes. Basic process was to progressively drill out CIS collars. They are made of two part If I remember correctly . Outer part is what sticks out of the head. There is a inner part that looks to have been pushed in to hold the outer part. I will have to look at drill sizes I used. Drilled inner part until it came out. Drilled outer part until it was thin enough to pull out of head. This leaves a pretty large hole. I was planning on tapping and sealing with threaded plug or bolt. I will look for drill sizes I used and post (taped them together as I have another set I want to do the same).
john
Old 03-09-2020, 09:24 PM
You have been looking at this conversion since 2011. Why the extended delay?[/QUOTE]
I've been contemplating "things" about many automotive projects for just as long (or longer) than jyporscheboy. I'm curious as to why this matters.
Old 03-10-2020, 02:53 PM
HarryD's Avatar
I've been contemplating "things" about many automotive projects for just as long (or longer) than jyporscheboy. I'm curious as to why this matters.[/QUOTE]
Doesn't. Idle curiosity.
Harry
2020 MB E350 4Matic
Old 03-10-2020, 03:21 PM
E Sully's Avatar
I left the injector collars and rubber sleeves in place, then had the local shop make aluminum plugs in place of the injectors.
Ed
1973.5 T
Old 03-14-2020, 05:13 PM
E Sully's Avatar
A quick pic of the plugs installed in my 73.5. The end was threaded so a bolt could be threaded in for removal. I sold them years back when I decided to return to CIS.
Ed
1973.5 T
Old 03-29-2020, 11:14 AM
Send a message via Yahoo to rgofast
I’ve got some CIS heads on the bench. The sleeves are one piece aluminum, and drive out from the inside The remaining holes can be welded shut, or threaded and a plug installed. You might check with Richard Parr at PMO. They used to make kits for converting injected cars to carbs. I wouldn’t try to drill them out with the heads still on the engine.
1969 911TR lightweight, 1850 lb. 245 HP 2.7 short stroke
1973 1/2 911T S optioned sunroof coupe (in progress)
1998 993 Carrera Cabriolet PSS10 lowered E88 cup wheels
1999 996 Carrera Cabriolet
Old 03-30-2020, 01:48 PM
