-   -   Cant get spark plug out (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1055381-cant-get-spark-plug-out.html)
Jd21476 03-19-2020 11:23 AM
I have a 3.2 and I was able to pull all the other plugs using a 13/16 spark plug socket with a swivel adapter but the middle plug on the passenger side just wont grab. I have taken the valve cover off and have tried for over an hour by fiddling with the socket in the hole but it just wont seem to grab. Any ideas?
arbita1 03-19-2020 11:54 AM
Are you sure there is one in there. Put your phone in there and take a photo to see what’s going on.
flyingjay 03-19-2020 01:48 PM
Two things that sometimes happen. The rubber boots from the spark plug wires can sometimes come off the wire itself and stay on the spark plug. This will result in you not being able to get the spark plug socket on. another thing I have found is that certain sockets are too large and will not fit into the recess of the head. I highly recommend getting a hazet or gearwrench magnetic socket. In my opinion, both of the sockets are great and have enough clearance to fit in the small recesses. I usually see this problem on #1 and #6 cylinders.
Jd21476 03-19-2020 08:40 PM
Finally got it out. I switched sockets and the new one worked perfectly on that plug
flyingjay 03-20-2020 07:48 AM
Awesome
