Transmission rebuild/upgrade
I searched for read threads and could not find anything.
Where does a guy start with transmission reconditioning and performance improvements, specifically for the 915 trans?
I know nothing about transmission repair/upgrading beyond adding a big clutch and throw out bearing.
If you were to have a 2.7 rebuilt with itb’s for a car designed for driving to the track.....what would you do to the transmission?
Keep your stick on the ice!
69 911T
Old 04-02-2020, 04:02 AM
Location: behind the redwood curtain, (humboldt county) california
Track prep 915
I just had California motorsports go through my 74 915. I haven’t the tools or knowledge to do the job, ( now, I’ve got the time to learn :-)
I am adding PMO itbs/EFI to a recently freshened 2.7 and it will see some track use, so, I opted for the Guard LSD, Wevo shift gate, reinforced side plate and teddy bear bearing support. Second gear had a weld repair to strengthen it.
Third or 4th gear and the r&p were also replaced, worn out. All of the above was in addition to the usual stuff, bearing bore repairs, bearings, sliders and synchros.
Had to Build a shipping box and screw it to a palate.
Recently, 915 parts are being manufactured with a gold alloy, so the prices are commensurately higher, an eye watering 13k.
If you are going to do significant tracking, depending on your HP, you might want to consider a spray bar/cooler set up to give the box a chance. Talk to the pros about when this is advisable and possibly changing your gearing.
Good luck,
chris
Old 04-02-2020, 07:42 AM
Harpo's Avatar
Chris,
What is a teddy bear bearing support?
Old 04-02-2020, 09:21 AM
flat6pilot's Avatar
Originally Posted by chrismorse View Post
I just had California motorsports go through my 74 915. I haven’t the tools or knowledge to do the job, ( now, I’ve got the time to learn :-)....
Recently, 915 parts are being manufactured with a gold alloy, so the prices are commensurately higher, an eye watering 13k....
Good luck,
chris
Wow! I just bought a rebuilt SBH 930 gearbox from Brian for my turbo'ed SC this past October for $9500 (included a $2000 core charge.) I guess I don't feel so bad now. Geez...
Kyle - 1980 RoW non-sunroof 911sc - 3.2 Turbo, Mahle P&C, Carrillo Rods, Megasquirt II (Fuel Only for now), re-geared 3rd and 4th 930 gearbox, 2350lbs
Old 04-02-2020, 01:37 PM
Good luck,
chris
Great starting point thanks Chris.
I should correct myself, I won’t be using it at the track for racing as much as I’ll be getting driving lessons so I can learn to go fast. I want a fun motor for my outlaw that can drive there. I’ve got a trailer for when I brake it.
Yes, what is the teddy bear bearing support? Sounds technical, sounds German. 😀
69 911T
Old 04-02-2020, 05:12 PM
Under the radar
Trackrash's Avatar
There have been a couple of recent threads on 915s.
What 915 do you have? I see '69 in your garage.
So, I'm guessing you want to upgrade your trans for your 2,7? I would recomend a mag case 915. Better gearing and will fit with less fuss than a newer trans.
Scroll down in this thread and see some good info. Project Heavy Metal - an all steel classic, remastered
More good info. Gordo's 915 Transmission Rebuild
Teddy bear. https://www.pelicanparts.com/More_Info/CMS915BRT.htm?pn=CMS-915-BRT&msclkid=4214512d94d91fbaf18f0fab1eedfd56&utm_source=bing&utm_medium=cpc&utm_campaign=Shopping%20Ads%20-%20Porsche&utm_term=4581115198205407&utm_content=%24200%20-%20%24400
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-02-2020, 06:09 PM
Teddy bear
The teddy bear is a one piece bearing support, rather than the original two piece retainers. This helps retain the two bearings, (and shafts), maintaining a more precise location - keeping the shafts from spreading, misaligning the gears.
It probably helps prevent the bearings from loosening and spinning in their bores, as well.
chris
Old 04-03-2020, 07:48 AM
the bear!
chris
I've never heard to it being referred to as the Teddy Bear support, but I totally can see where it comes from! If they still call it that in years to come, I shall remember I saw it here first
Old 04-04-2020, 03:22 AM
Racer
winders's Avatar
I like “snowman” more than “teddy bear”.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 04-04-2020, 03:36 AM
Stranger on the Internet
patkeefe's Avatar
Peter Zimmerman has an excellent tutorial regarding the 915.
I sent mine to CMS a few years ago. It needed some special machine work, and I had them rebuild it plus add LSD. $6500. 915's are becoming rarer, and fewer parts are available.
Patrick E. Keefe
78 SC
Old 04-04-2020, 11:29 AM
Under the radar
Trackrash's Avatar
Adding to the above, be careful buying a used transmission of unknown background. A junk trans will cost a fortune to refurbish.
Gordon
Old 04-04-2020, 02:15 PM
gearhead
As referenced above, the definitive 915 document:
How-To: Porsche 915 Transmission Repair Tutorial Part 1 - Porsche Wiki
Even if you are going to send it to a specialist, it’s worth reading for information purposes and an understanding of improvement and upgrades that occurred to them over time.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 04-04-2020, 05:51 PM
