buster73's Avatar
66mm 935 crank for magnesium case ?
Still going through the options for my 2,4 project based on a 73 2.4 7R case. Now I was offered a brand new 66mm 935 crankshaft complete with titanium rods and bearings. Did some research and seems most 935 engines were based on early turbo cases, so in theory the crank should also fit a 2.4 magnesium case ?
However my gut feeling is that this crank would probably be „over-kill“ for an early case and with all limitations of case and other components (heads…) you can not really take full advantage of the potential of a 935 crank. Probably no significant benefit compared to a 66mm 2,2 S crank unless you go really wild on the engine specs.
Appreciate your advice.
Regards,
Guenter
73.5 911T, mod
Old 08-20-2025, 09:33 AM
gearhead
I can’t imagine that’s cost effective in any way. And yes, overkill.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 08-20-2025, 11:00 AM
Try not, Do or Do not
Henry Schmidt's Avatar
I would have to agree with Matt. A factory race crank with titanium rods would be designed for performance far exceeding the limitations of a 2.4/2.7 magnesium case.
I will also add, I have never seen a 66 mm, 6 bolt, 935 crank. 9 bolt sure, they were used in 962, 956 as well. I doubt it exists.
Please post picture of the crank and ti rods.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 08-20-2025, 12:06 PM
Rosco_NZ
Send a message via Skype™ to Rosco_NZ
I understand the 2.1 turbo RSR was built on Mg cases (& 915 trans). I know these days we know the limitations but weren’t the 2.8 RSR’s also Mg cases?
Old 08-20-2025, 12:45 PM
This has to be a 9 bolt crank (won't fit). If 6 bolt it's 906. (Will fit)
Old 08-20-2025, 12:56 PM
Porsche race engineers were enamored by the weight saving of magnesium. The original sand cast 2.0 cast was a pig.
They even tried sand casting a magnesium version for the 906 and those engines would crack everywhere.
Like most racing developments you build out until it fails. The 2.7 street engine and the 2.8 RSR are perfect examples.
The 2.8 suffered crank failures, harmonics that spit the flywheel off and insufficiency in case stability. Cracking everywhere.
Those issues facilitated the need for a purpose built crank and a sand cast 3.0 case that closely mimicked the 2.0 sand cast cast.
Here's a 906 case we repaired.
Henry Schmidt
Ph: 760-728-3062
Old 08-20-2025, 01:58 PM
Sand cast, aluminum 3.0 RSR
Henry Schmidt
Ph: 760-728-3062
Old 08-20-2025, 02:26 PM
buster73's Avatar
Thanks for your advice. Confirms my doubts that this crank is no option for my project. The owner was racing RSRs in historic racing for many years and has this crank in storage since. At the moment he does not have more infos than it is a 66mm crank. Will ask him for more details and pictures once he found it in his stash of parts. Of course we also have not talked about pricing yet and guess even a „friendship price“ would blow my budget.
Regards,
Guenter
73.5 911T, mod
Old 08-21-2025, 02:43 AM
PCA Member since 1988
Add this: If the crank and rods were used in racing, you don't know how much abuse they have already endured, and how much useful life they have left.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 08-21-2025, 11:14 AM
