Where does this piece come from?
Hi Guys,
Can anyone identify what this object is, or is a part of?
Found in the oil sump screen on a 3.0L 930 aluminum case.
It has a curve to it, it has serrated surface on the inside, smooth surface on the outside. Probably 2 x 5 mm piece as shown below. It is not magnetic so my best guess is that it is a piece aluminum.
I've entertained the idea of this object being:
- piece of the pressure relief pistons -> seems to be too big for the object to come from the piston
- piece of piston squirter -> maybe it could be a piece of the squirter housing, but I'm having a hard time imagining what would cause a squirter to break.
Ideas and suggestions are welcome.
Object:
Reference picture of squirter:
Reference picture of pressure relief piston:
Old 04-09-2020, 05:45 PM
Looks like a chewed on valve retainer to me
Sent from my Nokia 7.1 using Tapatalk
Old 04-09-2020, 07:48 PM
I think valve keeper also , ( believe that is what the previous poster meant ) .
Old 04-09-2020, 08:20 PM
Valve keepers are magnetic as far as I know. This piece is not magnetic.
Old 04-09-2020, 10:29 PM
Under the radar
Trackrash's Avatar
looks like a piece of debris left from a machining operation. Perhaps a shaving from the removal of a valve guide? What else is brass in the motor?
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-10-2020, 11:58 AM
I'm stumped right now too. The guides are 9mm, so that's a bit small. The other bronze/yellow colored bushings are on the timing chain idlers, rocker arms, and small end of the con rods, but they're all way bigger than that.
Unless it came out of a chain tensioner? It's been awhile since I've pulled apart an old style tensioner.
Let me think about it more over the weekend. I'm putting together another 930 engine anyway, so I'll keep an eye out.
Old 04-10-2020, 04:38 PM
Banned
If items showed are non magnetic, they are from an outside source.
Old 04-11-2020, 07:26 AM
It's a 914 ...
stownsen914's Avatar
In the first pic, the piece looks more golden in color like a bushing. In the third pic it looks more like aluminum.
Old 04-11-2020, 08:10 AM
It's a 914 ...
Can you share the logic in coming to that? There are non-ferrous parts all over the engine. And how would it enter? This piece didn't come through the oil pump.
Old 04-11-2020, 08:12 AM
It appears that way on pictures due to the lighting on my work bench, however it is a classic frosty silver-ish aluminum color.
Old 04-11-2020, 03:00 PM
