67 S worn barrels options
67 S 911
Std barrels and pistons. Barrels are too worn for a hone.
S heads and I think E or T cams.
Good used set in a bigger CC
New pistons and bore .5mm
Reco my barrels.
AA barrels pistons.??
What size will bolt on and work ( can I get more torque)
Its a weekender not a race car.
Thoughts
Thanks Lyndon
Old 04-08-2020, 10:28 PM
It's a 914 ...
stownsen914's Avatar
How far out are they? There are coatings you can put on your used pistons these days to increase their outer dimension by a nominal amount to account for a slightly larger bore due to honing.
Edit - just saw your other thread. 0.5mm is probably more than a coating will buy you. That's a lot just to true up your cylinders. Are they scored?
Other options include nikasil plating the cylinders back to standard side so you can reuse your pistions, or buying oversize pistons. 81mm is a common size off the shelf, or have a custom set made by companies like JE or CP which is more $$.
Old 04-09-2020, 08:06 AM
They have had moisture in them. 20. Thou would fix them.
Lyndon
Old 04-09-2020, 09:24 AM
Aren’t a set of 2.2 pistons and cylinders available? I believe it’s just a bolt on upgrade.
-Andy
Old 04-09-2020, 09:31 AM
It's a 914 ...
-Andy
2.0 uses a different head gasket, I believe. Not quite bolt on, but it could be done. Possibly cheaply if you can find a good used set of P&Cs. One thing though is I think I remember that the 2L heads have a larger combustion chamber due to the steep inclination of the valves, so you'd lose compression ratio using 2.2L pistons compared to the standard application.
Old 04-09-2020, 10:16 AM
Have the cylinders bored / honed .5mm bigger and buy a set of Wossner pistons ( stock item ) , or maybe get a Nikasil coating to stock dimensions . Mahle sells new P's and C's , but they are actually for a 906 engine , so a bigger cylinder base shim is required and cutting the piston dome to lower the compression ratio .
Old 04-09-2020, 08:34 PM
Do to have a wossner part number
Old 04-09-2020, 08:41 PM
It's a 914 ...
Here's the JE 81mm 9.5:1 pistons
353219 Product Detail Information - JE Pistons
Old 04-10-2020, 07:25 AM
Am I correct they are not a good every day pistons when compared to other pistons. ???
Lyndon
Old 04-10-2020, 04:35 PM
Nikasil-coated cylinders need compatible pistons. Early S pistons could be a match. Review this archived link:
Using Alusil pistons in Nikasil cylinders
An option for your planned operating conditions. If the pistons are to spec, resleeve the existing cylinders, then hone to arrive at spec. clearances.
Sherwood
Old 04-13-2020, 12:11 PM
Just remembered. I have a set of 2.2 base pistons and cylinders that are slightly out of spec. Let me know if these are of interest. Been in dry storage for +30 years.
Sherwood
Old 04-13-2020, 12:30 PM
Wossner 2.0 911S pistons , assembly or part no. 9412 , $979.00 . Available for 80mm
or 80.5mm cylinders .
Old 04-13-2020, 08:34 PM
