1/4" end play on oil pump
So I had no oil scavenge going on in a newly built motor.
It would fire up and run fine but oil pressure would drop from 50psi to 7 or 8 psi after running about a minute or so. Verified with a mechanical gauge.
Hmmm, oil tank was empty. OK, drain crank case of 12 quarts of oil, pour back in oil tank, repeat. Same outcome.
Thought I had lost or crimped an oil pump oring, on tear town, no such luck, all orings virginal and accounted for.
Examined oil pump and the scavenge side has roughly a 1/4" of end play
What do you guys think?
Old 05-01-2020, 04:11 PM
It's a 914 ...
stownsen914's Avatar
Nope, that's not right. Sounds like the scavenge portion of the pump can't draw a vacuum to suck out the oil, probably due to the gap. Was the oil pump disassembled when the engine was apart?
Old 05-01-2020, 06:15 PM
right, 2-4 thousandths is industry standard for oil pumps.
So I am 100 times what the clearance should be.
This is a pump I sent to Glen Yee for the GT1 mods and was fresh from his shop. More slippery slope money pissed away.
I will be doing a forensic tear down of this pump once I get the motor back together with a different pump and have the time.
Look for it, I have a feeling it will be entertaining.
Old 05-02-2020, 10:02 AM
It's a 914 ...
Strange and a total pain for you. Sorry that happened. Sounds like it got assembled with the wrong gears.
Old 05-02-2020, 12:53 PM
Under the radar
Trackrash's Avatar
^ +1 . Send it back and see what they say. Are the end bolts on the pump tight?
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-02-2020, 01:51 PM
