What is this engine...? (3.0 Stroker?)
Hey All,
Been doing a bunch of research to try to see if anyone has built an engine like this before, but not really having any luck. I got this motor with a project I acquired a while back, and trying to see if anyone has built one like it.
It sounds like a 3.0 with a 3.6 crank, yielding a displacement of ~3.4.
Here is a spec list from the seller...
3.0 Case
Carrera Oil Pump
Twin Plugged
3.6 STD/STD Crankshaft
Custom Single Belt Pulley
Forged 11:1 JE Pistons
Machine matched Nikasil cylinders
GE-80 Profile Web Cams
Carrera Tensioners
Intake Ports Cleaned to 40mm
Exhaust Ports to 38mm
High performance valve springs
Curious if anyone has experience with this type of build.
Thanks in advance!
Old 04-28-2020, 10:47 AM
Puny Bird
Mark Henry's Avatar
Sounds like a healthy engine, you'll need EFI or 46mm carbs.
If it's primarily a street car you might want to change the cams to something with more lower rpm grunt and drivability.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 04-30-2020, 09:39 AM
