Timing Chain - stretched or normal?
Motor has travelled approx 300o miles since rebuild.. new PIWIS timing chains and sprockets on IMS shaft.
I notice that left side tensioner is extended a little more than the right side tensioner. Never really paid attention to it till now. So cannot say for certain if it was like that when I put it together.
So, is this relatively normal? or should I be thinking to swap out the chain? Advice I've been given so far, is that this is relatively normal. There is still a relatively large space above the idler arm, before it reaches the chain box.
Thanks for looking.
Old 05-02-2020, 06:33 PM
chain stretch
When the chain sprockets have wear the tensioner shaft will extend a little more to compensate.Looks normal.In the future just use the racing chain as they are prestreched.Fred
Old 05-03-2020, 08:20 AM
VFR750's Avatar
Did you replace all sprockets? If not then the extended tensioner makes sense.
Old 05-03-2020, 01:21 PM
Really?
I just learned something new.
Old 05-03-2020, 01:26 PM
sprockets on IM shaft are brand new. But not the ones on cams and idlers.
Old 05-03-2020, 02:10 PM
Under the radar
Trackrash's Avatar
Here is my new chain just installed. IMO, you are good to go. On my last motor, I left out the base gaskets and had the heads machined. They looked similar to your chains and I ran it that way for 80K miles with no problems.
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-04-2020, 08:03 AM
BURN-BROS's Avatar
I am hearing reports of a problem with the sprockets bought thru Porsche. Premature wear and Lots of metal on the drain plug magnet
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 05-04-2020, 11:47 AM
Are there better quality aftermarket chain sprockets on the market?
Thanks,
Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her!
Old 05-04-2020, 12:59 PM
BURN-BROS's Avatar
The one's in question are made by Sebro. they are apparently the Supplier to Porsche now. They also sell a aftermarket sprocket.
Right now, I have heard the Rauch and Spiegel seem to be OK, however all of this is second hand information.
I have seen pictures of the wear and it's not pretty. The wear happens at the valley of the tooth where the chain rides.
Burnham Performance
Old 05-04-2020, 01:20 PM
hi Gordon
looking at your pic, the plunger from your tensioner is extremely compressed. What does your left side look like, compared to the right side?
Old 05-04-2020, 04:16 PM
sorry to jump in... but is it good advice to buy a new chain on a 100k+ mile motor?
I wasn't sure if I can reuse my original chain or if I need to buy a new one.
1987 Porsche 911 Carrera Coupe
Old 05-05-2020, 01:06 PM
Under the radar
Trackrash's Avatar
If you split the case it is normal to replace the chain.
Originally Posted by mikedsilva View Post
hi Gordon
Sorry, I can't find a pic to the other side with the tensioner installed.
The thing I find interesting is your chain on the right seems to be about the same distance from the plastic guide as on my motor.
Gordon
Old 05-05-2020, 01:34 PM
The other possibility is that the cams are now closer to the crankshaft after the overhaul. Were the heads flycut/cleaned up where they meet the cylinders? Were the cylinder base shims omitted or were thinner ones swapped out? Were the cam towers machined flat? Any of these things would cause a similar scenario as "chain stretch."
Old 05-05-2020, 04:01 PM
Actually, to me it looks like you have a larger gap between chain and the guide. Which makes sense.
I'm not really too worried about it all. Going to button it up when my rockers arrive back from Craig.. he posted 2 weeks ago, and I still don't think they have left American soil yet!
Old 05-05-2020, 06:03 PM
I gotta ask.. what's that washer setup under your cam bolt?
Old 05-05-2020, 06:04 PM
Chains don't stretch. They become "longer" when the chain pivot pins/holes wear and/or the chain sits lower on worn sprockets, sometimes a result of lube oil or lube dilution.
An engine I built long ago had enough crankcase spigot, cylinder and cylinder head machining that it required, in addition to shaving the chain box mount surface, a larger idler arm sprocket to take up the slack and restore the proper geometry for the chain tensioner/idler arm.
Sherwood
Old 05-06-2020, 01:10 PM
Under the radar
Trackrash's Avatar
That temporary setup allowed me to set my timing without removing the wonderful new washer, when removing the pin, that Porsche uses on the new style cams.
Gordon
Old 05-06-2020, 02:06 PM
