Rocker adjuster screws seized
Progressing slowly on the rebuild of my 1986 930 engine. The previous owner over-torqued most of the adjuster screws on the rocker arms. They will screw in and out a bit but the deformed section of thread stops me from removing them. I tried holding them in the bench vise and using a screw driver bit on a 1/4 drive ratchet. Even with some moly on the threads it gets stuck. Should I just cut them off and remove? Should I try a thread repair die?
I am removing the adjuster screws in prep to send the rockers off for rebuild. David Performance EngiNerding |
I sent my rocker arms off to rebuild and i had to cut mine off with a dremel tool, will have to replace 5 of them.
![]() 914 6 Turbo twinplug 3.12 87 924S Lexus SC400 Lexus LS400 |
Before I cut them, I would try using a die.
1990 964 Coupe 1986 Carrera 3.2 Targa |
8mm x 1.0?
It's a 914 ...
Sometimes the split portion of the threads where the screwdriver slot can deform from over-tightening. A die, or cut and re-slot with a Dremel.
Puny Bird
Correct, but I found that my rocker threads were damaged as well. The die only helped me barely get the screw out, I had to use a tap to chase the threads before it would accept a new adjuster and turn smoothly.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. Last edited by Mark Henry; 06-22-2020 at 05:27 PM.. |
adjuster threads
Most of the time the threads are deformed from over tightening the jam nut, I secure the rocker and run the adjuster backward and pop the foot off, then chase the threads in the rocker replace the adjuster and good to go !
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
Does the foot just.pop back on?
foot
I imagine it would, but if the threads are deformed enough where you do this to save the rocker it need a new adjuster
Mike Bruns
