Rocker adjuster screws seized
Progressing slowly on the rebuild of my 1986 930 engine. The previous owner over-torqued most of the adjuster screws on the rocker arms. They will screw in and out a bit but the deformed section of thread stops me from removing them. I tried holding them in the bench vise and using a screw driver bit on a 1/4 drive ratchet. Even with some moly on the threads it gets stuck. Should I just cut them off and remove? Should I try a thread repair die?
I am removing the adjuster screws in prep to send the rockers off for rebuild.
Performance EngiNerding
Old 06-21-2020, 12:04 PM
iamchappy's Avatar
I sent my rocker arms off to rebuild and i had to cut mine off with a dremel tool, will have to replace 5 of them.
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 06-21-2020, 01:47 PM
Before I cut them, I would try using a die.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 06-21-2020, 02:14 PM
8mm x 1.0?
Old 06-21-2020, 03:52 PM
It's a 914 ...
stownsen914's Avatar
Sometimes the split portion of the threads where the screwdriver slot can deform from over-tightening. A die, or cut and re-slot with a Dremel.
Old 06-21-2020, 04:07 PM
Puny Bird
Mark Henry's Avatar
Originally Posted by reclino View Post
8mm x 1.0?
Correct, but I found that my rocker threads were damaged as well. The die only helped me barely get the screw out, I had to use a tap to chase the threads before it would accept a new adjuster and turn smoothly.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 06-22-2020, 09:54 AM
adjuster threads
Most of the time the threads are deformed from over tightening the jam nut, I secure the rocker and run the adjuster backward and pop the foot off, then chase the threads in the rocker replace the adjuster and good to go !
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 06-23-2020, 03:00 AM
Does the foot just.pop back on?
Old 06-23-2020, 09:03 AM
foot
I imagine it would, but if the threads are deformed enough where you do this to save the rocker it need a new adjuster
Mike Bruns
Old 06-25-2020, 03:53 AM
