2.2S vs 2.7RS so-so specs
Hi guys, id like a little poll on this. I have gathered parts to rebuild from ground a 2.7 to so-so RS specs using:
- Mahle RS 90mm p/cs 8.5:1
- Webers
- E-cams
- Headers
But also have a solid 2.2E bottom end with S-cams, that i could just slam S-pistons in:
- JE?s 85mm 10.5:1 pistons
- E Byral cylinders honed to 85mm
- S-cams
- Webers
- Headers
Your choice and specs for both of them. Thanks!
PCA Member
2009 Audi A3 2.0 Quattro
1978 911 SC Targa
Old 04-15-2003, 04:55 PM
Navin Johnson
TimT's Avatar
The 2.2 will be an S w/o mfi....power from 4000rpm+
The 2.7 will have a bit more torque
what heads are you using for these engines?
either engine will be loads of fun in a light car..
'69 911 GT-5
'75 914 GT-3
and others
Old 04-15-2003, 05:01 PM
Hi Tim, would be using the stock heads ported to correct specs. To use in a 914/6 conversion. Sorry, i should have mentionned.
PCA Member
1978 911 SC Targa
Old 04-15-2003, 05:05 PM
Warren Hall Student
Bobboloo's Avatar
As the saying goes... there's no replacement for displacement.
Seriously, both would be great but I'd swap to put the S cams in the 2.7 and put the E cams in the 2.2.
2.7 liters and S cams go very good together. One of Porsches best combos. E cams are a better street cam for a 2.2
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 04-17-2003, 01:56 AM
