Crankshaft nose bearing
Wayne suggests curil T be applied to nose bearing. Am set to reassemble, but not easy to find his preferred.
What function does it serve? Any suggestions as to alternatives? Thx, guys. |
Check out the "sealant thread".
Curil T is now Curil T2. Many, ourselves included, use Threebond 1211 there. The idea is to add additional sealing beyond the O-ring that is installed in that bearing. The reason? That O-ring can/will at some point dry up/shrink and cause a very common leak. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Try not, Do or Do not
The issue with sealing #8 main bearing is more about #8 bearing saddle inconsistencies.
The glue is a simple way to add additional protection. We struggled for decades to avoid gluing an o-ring...yikes...bur after building 100s of these air-cooled engines, "better safe than sorry" seems a good rule. Curil t has it's purpose but this is not our recommendation. We have been using Three-bond 1211 for 20+ years. If the saddle is round you don't need anything but most aren't and 1211 is capable of sealing as much as .010" where CurilT has limited gap performance under even low pressures. It (Curil T) is great at preventing seepage especially where two surfaces are in constant flux. Cylinder base is a perfect example.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Below is very interesting phenomena...
The below is from my race motor that I tore apart last year. Had 100hrs on it. Look at how much the O-ring has been chewed up from venting air. I'm assuming it's because of the tight seal from the three bond 1211. In the Klassic assembly video's he talks about to be sure there is nothing blocking the 'breather' line in the nose bearing. I can definitely see why.
Senior Member
A more pliable and a couple thousandths thicker o ring is the answer.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
It's a 914 ...
@JoeMag - did you have any leaks at the nosecone bearing before teardown?
Too much glue improperly distributed. Very thin coat on the saddle and a secondary lip bead.
