-   -   how do you remove oil splash valves? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1066377-how-do-you-remove-oil-splash-valves.html)
Aircooled4evr 07-04-2020 01:32 PM
Hey guys,
how do you remove, and reinstall the oil splash (oil squirter) valve?
some good ideas? videos? :)
Cheers, mads
cgarr 07-06-2020 02:30 AM
use a 1/4" ball burr to cut the top off, go deep enough to remove the 3 stakes, pull the guts out, use a 5mm tap to go inside, heat up the outside alum and pull it out.
I use a bit of hard setting permatex on the valve, keep it away from the bottom, drive it in carefully with a 1/4" drift, stake it in place.
HaroldMHedge 07-06-2020 07:51 AM
Here's a good thread on removing the squirters.
*&%$# piston squirters
Aircooled4evr 07-07-2020 06:50 AM
Thanks for the advice / description Cgarr!
My tech english is not that sophisticated... But i hope i can get started (on a better note) with your advice!
I started the other day, armed with a YouTube video ... (in Spanish that I don't understand) :D and destroyed the first one ... :rolleyes:
Aircooled4evr 07-07-2020 06:54 AM
Hey HaroldMHedge. Don't know if I'm doing something wrong? But I can't open your link! :confused::)
HaroldMHedge 07-07-2020 10:12 AM
Here's the webpage link again. It should work this time.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/906368-piston-squirters.html
Walt Fricke 07-07-2020 08:50 PM
You do know that the piston squirters are always destroyed as part of the removal process?
Or did you destroy a new one putting it in?
Aircooled4evr 07-08-2020 05:46 AM
Originally Posted by HaroldMHedge (Post 10936656)
Wow... That was the holy grail of info! Thanks HaroldMHedge SmileWavy:):)
Aircooled4evr 07-08-2020 06:25 AM
No. I drilled it out like in the video but I couldn't pull it out like they did .. so now it's stuck. But I'm on the case, thanks to your advice. (and a good machinist friend) :)
I buy new ones when I can measure it all out.
HaroldMHedge 07-08-2020 08:36 AM
You should try some heat to release the squinters. Loctite 270, 620 and 640 require a temperature of 250C to break the bond.
