*&%$# piston squirters
This is bizarre. I took my cases to the machine shop to be cleaned. I checked all the squirters with compressed air before I sent them, all were fine except one which was stuck open. So I figured maybe it will clean up in the tank. I got the cases back and checked all the squirters again. The #1 squirter is still stuck open. But now I've got all three on the 4-6 case stuck closed?? The squirter drilling comes off the main bearing oil supply hole in the saddle right? I can see the hole to it just inside the saddle. I did the same as before, inserted a stud into the end of a hose and used it to plug the drilling from the saddle into the through bolt hole and applied air to the saddle hole. I went up to 120 psi and I get nothing from all three squirters!! Does anyone have a pic of these things? It's just a spring and a ball right? Does the ball seat on the drilling in the web with the spring on top of it and then the nozzle on top of the spring? I can get a spray wand from can of brakeleen into the drilling that goes directly to the squirter nozzle, maybe I should try a piece of wire down it to force open the ball? Crazy.
Old 03-16-2016, 11:44 AM
I think I found a pic - looks like a tube with the spring and ball enclosed inside? So it's the whole assembly that gets replaced, not just the nozzle? I'm going to get some MEK.
Old 03-16-2016, 12:51 PM
It's a 914 ...
stownsen914's Avatar
Try soaking with some penetrant? Strange that soaking the case made it worse, but they could be gunked up with something. Penetrant could loosen it up possibly or dissolve any gunk in there.
Old 03-16-2016, 12:55 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Here's a couple threads to give you some visual help
Piston Squirters Again
Oil (piston) squirter......
Try Seafoam?
Kevin L
'86 Carrera "Larry"
Old 03-16-2016, 02:10 PM
The Seafoam worked on #4 and #6! But #5 still wouldn't budge so I had to take drastic measures. A piece of .025 MIG wire pushed into the squirter supply hole finally got the ball unstuck from the seat. #1 still leaks so I'm replacing it.
Old 03-17-2016, 04:36 PM
Air Medal or two
afterburn 549's Avatar
Can i ask a dumb question?
Oil squirter target-
Where should it be aming?
Or, at what point in stroke where to his piston ?
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 03-18-2016, 05:49 PM
They point just about straight up from the top of the webs to the bottom of the pistons. The hole to the squirters intersects the hole supplying oil to the mains just inside the saddle surface so you can get a wire directly into the squirter hole. I had best luck with the mig wire, it's stiff yet can still be bent enough to direct it into the squirter hole. The syringe makes it easy to get the seafoam directly into the squirter hole.
Old 03-18-2016, 07:39 PM
Puny Bird
Mark Henry's Avatar
If you can't free them up they are not that hard to replace.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 03-20-2016, 09:19 AM
Air Medal or two
Would it be rude to ask for directions?
What holds them in?
Old 03-22-2016, 06:58 PM
They are held in by staking the web to deform the top of the hole that they fit in. A dremel and a slide hammer removes them.
Old 03-22-2016, 07:23 PM
I guess so, I've never had one out. I'm pulling one out tomorrow though. Will post some pics.
Old 03-22-2016, 07:55 PM
Air Medal or two
thanx !
Old 03-22-2016, 07:57 PM
Puny Bird
Mark Henry's Avatar
I drilled them and the bit got stuck in the squirter body, then I just yanked them out.
One I had to pull out with a wood screw.
Old 03-22-2016, 09:42 PM
Puny Bird
Mark Henry's Avatar
I doubt if this was needed but I put a tiny bead of loctite 620 around the squirter.
The peening tool I made from grinding an old center punch.
Old 03-22-2016, 09:47 PM
Thanks, that looks easy enough. I'm just waiting for a parts shipment.
Your '67 Bug must fly with that monster engine. I've got a '65 double cab, all stock, needs an engine job.
Old 03-23-2016, 04:35 AM
Air Medal or two
Thanx for all the info!
Should a jig be made to redrill the hole if need be? (to keep the streak of oil on target )
Old 03-23-2016, 06:38 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Mark's got the right approach- agrees with the almighty Porsche service manual. Here's a snapshot from the 993 manual
Kevin L
'86 Carrera "Larry"
Old 03-23-2016, 06:55 AM
Puny Bird
Mark Henry's Avatar
I wouldn't redrill anything, unless you are making a jig to mod early cases for squirters.
Oversize I'd use a ream, maybe some sandpaper glued on a dowel. How much material is being removed for OS?
Anyways, I didn't have an issue needing OS squirters.
The factory manual says something about a 6mm tap I don't understand.
Is that for pulling the squirter out? (note, ok now I get it)
If so the #8 wood screw on a small slide hammer is all you need.
Loctite 620 and 640 are both sleeve fit retainer, but 620 is good to 450*F, where 640 is only rated at 350*F
I've used 620 for 25 years in aircooled engines with excellent results.
Old 03-23-2016, 07:43 AM
Puny Bird
Mark Henry's Avatar
I was thinking of putting squirters in something else...Looks pretty EZ
Type 1 or 4?
If you have real good oil pressure you can just notch the rods.
Old 03-23-2016, 08:15 AM
Puny Bird
Mark Henry's Avatar
Cool, pistons look a lot like the JE 102mm slugs in my VW bug.
You could just notch the rods with a .010 -to 015 notch filed aiming at the back of the piston. Oil pressure and centrifugal force will take care of the rest.
Old 03-23-2016, 11:15 AM
