Setting cam timing with engine in car?
Hi guys.
I just finishing an efi install after many years but had a leak at the chain housing to cam tower. Changed gasket and ring with engine in situ which was a pita job and thought i`d left cam timing untouched. So now it won`t run properly and goes lean etc then dies. So might have to open her up once more to time cam. Is this hard to do with engine in car? Positive is that i stopped the leak:D Thanks to any tips SmileWavy |
You have to remove all the muffler and metal off the rear of the motor including the motor mount
Disconnect electrical, fuel, oil and venting to lower the motor. At this point, take the half shafts off and pull the motor, put it on the table, you’ll be much happier Bruce |
oof. I trust your judgement sir so i`ll do that. thx for chiming in.SmileWavy
so much work and it`s coming out, again.:rolleyes: |
Turbo, lots more to come off...
Bruce |
Check the cam timing first before you go to the effort of removing the engine
How do i do that? Guessing removing the valve cover and mount the dial then turn the engine like i would to see like i would anyway?
Cam timing inspection........
If you could check your cam timing in situ, what’s the point of removing the engine? For cam timing work, I rather drop the motor and do the cam timing with motor installed in an engine stand. Tony |
Checking the cam timing isn't any harder, really, with the engine in the car than with it on your engine stand. Of course you should do that before you do anything else. What is the overlap at the proper TDC for the cam you worked on?
I once did what you did - pulled the chain housing cover, removed the cam chain sprocket, found I had failed to tighten the three 10mm head bolts (hence big leak), tightened them, put everything back together as they were, and before putting the cover back on checked the timing. !it hadn't moved! I was astounded and elated. All in the closed trailer in a Walmart parking lot at Las Vegas before a race. You had to go a little deeper, but I think nothing which would have moved the cam necessarily if the pin went back into the same holes? Mind you, this was a race car, with a whole lot less to remove, and the bodywork cross piece behind the engine is removable as well, and not a turbo. If you could do what you did with the engine in the car, you ought to be able to retime one cam if needed. No engine builder would want to do it that way, of course. You are the one to balance the pain of the one with the effort to remove the engine, put it on a stand, then remove more stuff, and reverse the process. Hindsight - too bad you didn't check the cam timing as soon as you were done with the hard part, and before you started to put the cover and other stuff back on. Post hoc ergo propter hoc doesn't always work, either. You won't know until you check the timing of that cam if it is out of whack enough to produce bad running (luckily it seems not so far out of whack as to lead to valves hitting pistons). You just installed EFI, and there are no end of things which can cause problems there. For instance, the rebuilt injectors I bought didn't work (shop forgot a final lubrication step). In addition, the throttle position sensor, which should give a rising voltage signal as the throttle is opened, in fact gave a lower signal to begin with, and only at some point did what it was supposed to do! So if I could get the engine over maybe 1,500 or 2,000 RPM it would run OK. Just examples to suggest something else might be the cause. Check. But it might be off. |
And ofcourse taking out the engine and put it on a stand makes it easier to time the cams but so is changing the plugs when the car is on a stand but i`m not taking out the engine again just to do one thing unless i have to. Off with all the wiring again, axles, oil mess and all the trouble jacking it up to get clearance etc etc. If i had a garage with fancy tools then maby :D I`ll try in position first if i find the cam out of position. Thx for the input guys SmileWavy |
There are days when I think fondly of my air cooled VW beetles. I could pull the engine with a couple of wrenches and the car's jack in my trailer home driveway: Disconnect all but the bolts to the tranny. Remove rear wheels, set car down on a bit of wood under the engine. Undo the 4 bolts and slide the engine back a bit. Jack the car back up and pull the engine out. 911s are more work in a lot of ways.
Several of us are waiting to see what that cam's timing measures. |
He only worked on one side/cam, so that's the timing he needs to check. Checking the other cam also might make sense, since it is really easy. But probably won't help the diagnosis.
Thx guys for encouraging me SmileWavy
2 of my freshly rebuilt calipers was also leaking badly so i had to tackle that also today but i was able to check timing and also discover a small oil leak through the intake valve cover gasket. I actually remember forgetting to put loctight on the valve cover itself, only on the head side. I also remember thinking this would be ok. NO!! So a redo:rolleyes: Hindsight WF is always annoying but i agree, i made so many mistakes with this build because of shortcuts. Lots more work because of it but i have held the costs down. Wish i could just ship it to TK.:cool: Anywho, Exhaust off https://i.imgur.com/vBSQ02l.jpg Dial on but i adjusted it a bit so it was straight. https://i.imgur.com/0KcSgMn.jpg Timing around 0,95 if i`m not mistaken <blockquote class="imgur-embed-pub" lang="en" data-id="dDjkXmI"><a href="https://imgur.com/dDjkXmI">View post on imgur.com</a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script> And around 0,98 <blockquote class="imgur-embed-pub" lang="en" data-id="VQ2ikTH"><a href="https://imgur.com/VQ2ikTH">View post on imgur.com</a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script> Before chain box gasket/o-ring change. High idle but running great. I WAS so happy :D <blockquote class="imgur-embed-pub" lang="en" data-id="OeyYPJN"><a href="//imgur.com/OeyYPJN">View post on imgur.com</a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script> So is that far off enough to mess up cam trigger sync etc? Also, off with the turbo lower the engine just a little and i`ll time that fooker if needed in situ :D |
I adjusted cam timing with the engine in the car. Was no more difficult then with it on the engine stand. Was a 73 E so less stuff in the way than a more modern engine.
So the spare gasket i had laying around turned out to be wishful thinking. Had to do a parts run and finally my local Porsche Center had what i needed.SmileWavy
Love that Locktight 574 but it`s a mess too clean up when you use as much as i did. But it was perfectly leak free! https://i.imgur.com/u2WfXzX.jpg https://i.imgur.com/n24RFrc.jpg https://i.imgur.com/jjcVvlI.jpg So set it to about 72. On the video i took it just over TDC. <blockquote class="imgur-embed-pub" lang="en" data-id="goWAd3H"><a href="https://imgur.com/goWAd3H">View post on imgur.com</a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script> I will ofcourse agree that this would be easier to do outside on a stand but it`s no problem at all doing it in car. Only hassle is the sheet metal bolts. So tight and frustrating. 8 Conclusion is that this is something you do when the car doing valves, gasket changes etc but if you just need to time a cam, not a biggie. If i can di it.......SmileWavy Continues tomorrow with doing megasquirt again. Crossing fingers this was the issue i had!! Thanks guys!:D |
Good job getting in there and getting it done.
Good idea with the crank bolt access hole- they should have come like that. https://i.imgur.com/jjcVvlI.jpg |
Thx and congrats on your impressive build! SmileWavy
They absolutely should`ve yes. I must admit if this was a low mileage original collectors car i wouldn`t cut in it. It is not so out comes the angle grinder :D Also if the $ keeps dropping in value compared to norwegian viking coin i`m drooling on the TKs GT30 or 35 turbos to replace my 7006 laggy beast. Best thing about having a car you can work on is upgrading.:D Wonder how it is to drive ;) |
Access makes it easier to perform some operations. I hope I don't have to go here for awhile.
http://forums.pelicanparts.com/uploa...1595812802.jpg S |
| All times are GMT -8. The time now is 03:58 AM. |
