-   -   1980 engine rebuilt and in but won’t run (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1068950-1980-engine-rebuilt-but-won-t-run.html)
worn 07-31-2020 02:56 PM
1980 engine rebuilt and in but won’t run STILL
Finally I got the motor in my 1980 rebuilt and attached to the car. Want to run in everything but the motor starts and then dies after about 4-5 seconds. When it first starts it sounds pretty good, running up to 2-3 k RPM. I checked the timing, and it seems pretty close, with the timing light blinking away to indicate that #1 is firing for as long as the motor spins.
The motor:
911 SC with stock fuel injection
Dougherty DC15 cam shafts
Backdated SSI heat exchangers
While I was at it, 98 mm Mahle cylinders with CP pistons
MSD ignition with epoxy potted blaster coil.
The only thing new since it last ran are the pistons and cylinders.
Any suggestions? The thing will run, but only for short bursts. I cannot quite get from the key switch back to the throttle butterfly before it dies.
Left the whole mess lie on the lift and drove my TR6 home. Which was pretty good.
Flat6pac 07-31-2020 03:58 PM
Sounds like fuel delivery
Can you lift the air flow sensor while trying to run
You need help on the key...
Bruce
Walt Fricke 07-31-2020 05:15 PM
My thought too - maybe it is starting on the cold start valve's contribution, which is designed to be short lived.
You could disconnect the red/black wire on the thermo time switch to disable the CSV, and see if it even coughs when you try to start.
Time to acquire the system/control pressure checking gauge stuff and see what you have for cold control pressures, and for system pressure.
Another check: disable the fuel pump safety feature by pulling the plug off from behind the right side of the intake. This will allow the fuel pump to run as soon as the ignition is turned to the on position. Pull an injector and stick it into a bottle. Key on, lift the sensor and watch what comes out of the injector. It should flow.
If it does, and the pressures are reasonable, maybe the mixture screw is way out of whack? Hunting around on posts on CIS should lead you to some ways of setting the mixture screw to ballpark before you even try to start, I think I recall.
You can get a remote starter from a FLAPS for peanuts so you can be back there, but why? The pedal will blip the throttle just fine. Granted, adjusting the idle screw is better with a running engine.
I take it that you can't keep it going with the throttle? If you can, then it's not a CSV only fuel issue, but more likely a fuel quantity adjustment issue.
Your larger displacement means more fuel needed, but I'd not think that at idle that would be enough that with the throttle cracked it wouldn't keep running. And your cam you say worked with the stock ps and cs, so it ought not to be an issue.
ed mayo 07-31-2020 08:01 PM
It's possible you just have an air leak from something you missed in reassembly.
Bigtoe32067 07-31-2020 08:03 PM
Carb clean it and see if it stays running. That’ll tell you if it’s fuel delivery pretty simply.
Good luck
worn 08-01-2020 07:51 AM
I have the fuel pressure hardware, so it is off to test pressures today. Thanks so much for all of the help.
I er, ahem seem to have found a plug end. Here is a photo. I cannot identify it, but it might be important. It is on the engine wiring harness.http://forums.pelicanparts.com/uploa...1596293167.jpg
I know that I have plugged in: WUR, TPS, lambda valve, cold start valve, aux air, air plate switch. There are several red/white and ground wire possibilities on the wiring diagram...
THanks.
911 SLANT 08-01-2020 08:12 AM
This is exactly why I went with carbs on my 1976 911S CIS car. Much more easier to diagnose.
Lyle O 08-01-2020 08:27 AM
That connector looks like the one for the heater blower motor. Hard to tell from the photo, though.
worn 08-01-2020 10:45 AM
Here is another angle. Heater blower wires are accounted for.
http://forums.pelicanparts.com/uploa...1596303815.jpg
Any more thoughts?
gsxrken 08-01-2020 12:40 PM
On the turbos there are two plugs like that go on solenoids for distributor related vacuum advance and retard for warm up and pollution control. Not saying that’s what they are on your ca but they look similar
worn 08-01-2020 02:32 PM
Disconnected wires from thermo-time switch. No change in behavior. Motor spins up to about 2k rpm, sounds great for a few seconds - then dies with some backfires through the intake.
"Time to acquire the system/control pressure checking gauge stuff and see what you have for cold control pressures, and for system pressure."
Yeah. Need to hook it up.
Key on, lifted air plate. Fuel pump ran and injector #4 at least sprayed fuel.
"If it does, and the pressures are reasonable, maybe the mixture screw is way out of whack? Hunting around on posts on CIS should lead you to some ways of setting the mixture screw to ballpark before you even try to start, I think I recall."
I will check that out.
"I take it that you can't keep it going with the throttle? If you can, then it's not a CSV only fuel issue, but more likely a fuel quantity adjustment issue."
I can keep it going with the throttle. But iyt isn't very stable, so the rpms zoom up and then down with backfires in intake.
boyt911sc 08-01-2020 03:51 PM
CIS troubleshooting.........
worn,
If I were in your shoes, I would check the following:
  • Inspect if the CSV is working.
  • Use a smoke generator to locate hard to find leak sources if any.
  • What are your fuel pressures (CCP & SP). You can not check the WCP at this point.
  • Refrain from tinkering the fuel mixture. Wait until you get the motor to start and idle.
Keep us posted.
Tony
Walt Fricke 08-01-2020 04:00 PM
Red/Wt//brown connector. Maybe for the rear window defogger?
So, sounds like you are getting fuel (which is better than not). And enough that you don't need the CSV to start promptly?
Which suggests maybe mixture is way rich?
Have you pulled a spark plug? It might be wet with fuel?
Flat6pac 08-01-2020 07:02 PM
That plug For thermal switch isn’t used on an 80 and later
Bruce
Jeff Alton 08-01-2020 10:22 PM
Start with the basics. Verify compression and leakdown in each cylinder (should be done on every build). Verify cam timing and ignition timing. Smoke test for vacuum leaks. If all good, then start diagnosing the CIS system
mikedsilva 08-02-2020 02:13 AM
Don't laugh at me, but does the oil cap need to be on? Like on a 3.2 ?
Could the vent hoses be incorrectly connected?
jcvass 08-02-2020 07:52 AM
3 litre
pull 1 injector out of its fitting in the intake runner and have someone hit the ignition or use a remote switch of the starter . See if you are getting fuel delivery to the injector and or push the plunger up under the fuel head and see what kind of spray pattern you have . Sounds like a fuel problem . Verify that the pump is running as well
al lkosmal 08-02-2020 08:21 AM
no-start
The connectors for the cold start valve and the fuel pump shut-off (air-flow switch) are the same color.....if the mating connectors are connected to the incorrect place...I.E. if the cold start connector is connected to the fuel pump shut-off and vice-versa.....it results in a no-start condition like you are describing.
Easy test....swap the cold start connection with the fuel pump connection and try to start/run.
http://forums.pelicanparts.com/uploa...1596381622.jpg
regards,
al
Walt Fricke 08-02-2020 11:30 AM
Good point, Al. Easy to make this mistake after the engine was out. Would the CSV plug attached to the safety switch cause the fuel pump to run as soon as the key is turned to on? Or would it provide a ground for the FP relay?
Looks like it would provide a ground for the CSV, and maybe some current via the FP relay coil as well? But enough? But either a ground or no ground to the FP relay? Which would have no effect either way? Or a dead short?
Won't start turns out not to describe the problem. It does start, even without the CSV being hooked up (unless connecting the safety plug to the CSV causes the CSV to run continually). It just won't stay running without some fair amount of throttle, and then poorly it seems.
A CSV which kept spraying would certainly make things way over rich.
One test of all this would be (perhaps as part of checking connections) to disconnect both and try to start it.
al lkosmal 08-02-2020 03:13 PM
easy thing to check.......
worn 08-02-2020 04:25 PM
Thank you so very much folks. I go tomorrow armed with a fuel pressure gauge, a mirror and a goose neck camera. Don’t have a smoke machine but suspect an air leake because it backfires through the intakes. I noticed the possibility of plug switheroos too. I think I have it right, but am not sure. In the end I am ready to drop the motor out again and triple check.
But first I will use all of your suggestions. You guys rock.
worn 08-04-2020 01:58 PM
I was so convinced that I had a vacuum leak that I went over photographs, used mirrors and boroscopes. And didn't find anything. So, I hooked up the pressure gauge and this revealed-
System Pressure: 4.5 bar. A little on the low side but exactly what it was several years ago.
Control pressure: 4.5 bar. Not at all what it used to be.
So I removed the WUR and couldn't resist opening it. The innards are displayed below.
http://forums.pelicanparts.com/uploa...1596574252.jpg
Any advice on how to proceed? I am thinking that the way high control pressure leaned the mixture very rapidly on startup, leading to the engine dying with intake backfires. Maybe if I had finished the rebuild sooner the WUR would have gotten more use and it would have stayed more limber. Valve appears to be stuck shut.
boyt911sc 08-04-2020 04:15 PM
Fuel pressures.........
Worn,
For the control fuel pressure to be equal to system pressure, there is flow restriction to the return line. The restriction could be caused by a clogged WUR or a blockage any where along the return line. This is a partial blockage. A fully blocked return line will register higher than the system like 90 psi. Hope you are not using a HF brand CIS pressure gauge kit.
Are you sure the valve was opened when you did the test? Keep as posted. Thanks.
Tony
worn 08-04-2020 04:40 PM
Thanks Tony,
I was aware of the idea that return is blocked. I think it is blocked in the WUR, but I will explore further on. Hard to pressurize the banjo bolt fitting to tank return though.
Yes, it is an HF brand gauge. A man has to know his limitations, and I double check those tools, and have a lot of them.
Made a special point of triple checking the valve orientation. I have good reason to think that I conducted the measurements correctly. A reassuring point is that system pressure was dead on the measurement I made several years ago, but control pressure had changed. Also, I tried to blow air through the WUR, and it was blocked.
My car is kept in a building out of town a half hour or so. Circumstances permitting I will read up more tonight and possibly dissecting the valve tomorrow. If that is a dumb idea, now would be a great time to tell me. Thanks!!
boyt911sc 08-04-2020 05:28 PM
Quick test to locate restriction........
Worn,
If you get a chance re-assemble the WUR less pin, sombrero, and springs. Take another shot for the cold control pressure and share your findings. Just run the FP to check the fuel pressure. One more thing, could you measure the heater resistance (Ohms) of the WUR at room temperature?
http://forums.pelicanparts.com/uploa...1596587039.jpg
Keep us posted. Thanks.
Tony
worn 08-05-2020 08:11 AM
This is from memory, but I think it had a resistance of 26 ohms. Is your suggestion to doff my sombrero a test to see if the screen is plugged? I was worried about the plug being downstream of the unit, so as a naive worker, I blew into the inlet side until my cheeks puffed out. No flow. Then something seemed to pop and there was a little bit of flow. Unfortunately the 40 year old part was sitting unused for over a year while I got around to the engine.
Walt Fricke 08-05-2020 08:00 PM
Worn
I'd unbolt the electrical part so I could get at the four bolts which hold the diaphragm piece to the upper housing (left side in your photo). There are two passages leading to the diaphragm - one from the fuel distributor, and one to where the fuel bled off goes. One of these has a strainer in it - it looked like the steel slug which holds the fitting up top was machined so the hole didn't go all the way through. Then tiny holes were drilled through the disk shape in the bottom of the hole.
When mine showed CP=SP, uncovering and blowing brake cleaner through this screen solved things - at least as far as having a suitable difference between the two pressures was concerned.
It was hard to undo the four screws which hold the thick steel plate (with a hole in its center)which sandwiches the thin stainless diaphragm to the housing. They are slot heads! Eventually I got all four out, and replaced them with Allen heads from my local hardware store.
I'm not sure what Tony has in mind with pulling the sort of cup washer collar off. It is what the bimetallic electrical part presses down on when cold, so there is less pressure on the diaphragm, so lower CP and richer mixture. But Tony has these apart all the time, so he's got something in mind.
If you get the diaphragm part stuff off, you can blow in both directions. I'd use shop/compressor air and a rubber tipped air nozzle.
For pressure
cmcfaul 08-06-2020 01:31 PM
see if it will keep running if carb cleaner is sprayed into the air box. If yes then you know its a fuel issue. If no you know its electrical.
Chris
89 Carrera
worn 08-06-2020 03:04 PM
After taking the WUR all apart and cleaning it, I reassembled it and checked fuel pressures. Control pressure moved from way off to spot on for 21 degrees C. So, I took the plunge and managed to get the car running at about 1500 rpm for ten minutes. Trying to break things in. Should I change the oil now or run it another ten minutes or so?
Then my amateur exhaust hose bit the dust and I shut it down. Not sure I have the ignition timing quite right, but progress!
Thanks folks.
gsxrken 08-07-2020 05:32 AM
Congrats!
Peter Dawe recommended that I break in for 20 minutes and let cool down completely, change the oil filter, and then run the break in oil for another 500 miles (!) making sure to vary the rpms and not lug the engine.
worn 08-08-2020 03:53 PM
OK, it ran for ten minutes, I shut it down and now it won’t run. Starts but dies in about 4 seconds. I can sort of keep it going by opening the throttle but it isn’t stable.
The big surprise is that system pressure has dropped to a little more than 2.2 bar. The control pressure is very similar. Replaced fuel filter and gas flows freely through the filter and into a container when the fuel pump turns on. I am thinking about the fuel pressure regulator in the main fuel distributor valve. Any other possibilities? This is driving me crazy.
I have read and reread the Bosch book and cannot understand what else to check. Would prefer not to dive into the fuel distributor if there are other options.
Walt Fricke 08-08-2020 04:56 PM
This doesn't explain the way too low system pressure, but how is your pressure drop after shutoff? You know - see what the system pressure is, turn engine off, wait X minutes, see what it is now. There is a spec for that. If it falls too fast, you have hot/warm starting issues - the WUR and TTS think the engine is hot, and won't turn on the CSV or lower the CP.
But aside from that, as you guessed the system pressure is way too low. One pressure setting valve is (on some FDs) on the right. You can unscrew it and inspect. It is the one you can use shims (washers) to boost the pressure. It has an O ring or two. On some FDs it is toward the back? There is a small O ring down at the tip of this or one of these. It can go bad, and per the mechanic who told me this, drive you nuts trying to figure things out. It would lead to lower pressure. I'll see if I can find a diagram or picture of it.
But Tony could tell you in a Philadelphia minute.
Of course, the fuel pump could maybe be crapping out? My experience has been that they work until suddenly, and awkwardly, they don't. Maybe after a short period of making noise to complain, or maybe not. You'd have to rig up something to measure actual fuel pump pressure. As I recall, if it is pumping against what amounts to a closed system, it just recirculates without harming the pump. So the pump not being strong enough would be low on my list.
Walt Fricke 08-08-2020 05:25 PM
Here is a drawing of the push pressure regulating valve, and of that part of the system.
http://forums.pelicanparts.com/uploa...1596932452.jpg
http://forums.pelicanparts.com/uploa...1596932452.JPG
You can see where the two seals are
worn 08-08-2020 05:25 PM
Thanks Walt!
mike635 08-12-2020 10:49 AM
Might not be best to introduce more variables but thought I'd throw this out - I see that you're in Madison (assuming WI), I live in the area and have a spare, working WUR that was installed in my '81 SC for 10 yrs.
It's not the correct WUR (p/n 0438 140 009) but worked perfectly. I replaced it when I tracked down a working correct WUR (0428 140 090) and installed it just to make the system right, didn't make a huge difference but I feel better knowing it's correct with the frequency valve/duty cycle set to spec.
I'd be happy to loan it to you if interested, just send me a PM
boyt911sc 08-12-2020 01:19 PM
Fuel pressure.........
Worn,
If you are getting only 2.2 bar as system pressure you would be lucky to get the engine running. Installing a perfect WUR from your neighbor will not help you at all. What you need to do is find out why the system pressure dropped to 2.2 bar. There are two (2) likely culprits:
  • The fuel pump is bad.
  • The primary pressure valve is leaking.
If I were in your shoes, I would first check the condition of the FP. You could test it using volumetric flow rate measurement or a pressure test. If the FP is good, you have reduced the number of variables. Next, determine why a good FP could not produce sufficient system pressure. The primary pressure valve is located inside the FD (fuel distributor). Make sure you have a good pressure gauge.
Lastly, if you don’t want to do all these testings, send the WUR & FD to me and I will evaluate them for you for FREE. Your only expense is the postage to Philadelphia and back to you. And if you know someone willing to do test for you let them do it and I won’t be offended. It would take me about 3 mins. to evaluate the WUR & FD after I installed them on my CIS bench tester.
Tony
worn 08-12-2020 05:32 PM
Oh thanks Tony. Not sure that the free thing is legit though. But we can negotiate that!
Warren
boyt911sc 08-13-2020 05:56 AM
Parts testing and evaluation.........
Warren
Warren,
I have been helping fellow PP members for a while now and it makes CIS troubleshooting easier if you know that the CIS parts you are using are good and working right. In your case, you have some questionable component/s that must be confirmed or evaluated.
It only takes a few mins. to test and evaluate if a particular CIS component is good or bad. It would saved you from aggravation and frustration. Test and confirm.
Tony
Brian Cameron 08-14-2020 10:26 PM
When/if you get to that point, I believe this might be one of the posts referred to for ballpark setting CIS:
http://forums.pelicanparts.com/porsche-911-technical-forum/232089-cis-idle-speed-mixture-setting-without-analyzer.html
Tony is The Man so you’ll be ok with him in your corner.
Dave Kost 08-18-2020 05:04 AM
Engine Fails to Start
Here is a trouble shooting guide to test a no start. If you go thru these steps methodically, you will get to the issue.
Did you test the relay under the passenger seat is not blown? Can you confirm the Frequency valve is running? Your no start symptoms are classic FV not working. This should be the first thing you check on a 1980-83 CIS 911.
Sounds like you could have a fuel pump, blockage issue . Or interrupted voltage to the fuel pump.
Have you checked you have 11.5 volts at the fuel pump? Drawing no more that 8 amps.
Did you test fuel pump volume?
Did you reconnect and clean all grounds? Easy to miss reconnecting them. Maybe you are not getting proper voltage to the relays.
Last thing- Is the rubber peanut looking hat on top of the CIS box connected properly?
It's something stupid and I would check these things before sending or buying any new parts.
