Sikaflex vs Yamabond
Going to approach the #8 bearing leak for the last time and have heard Sikaflex and Yamabond work pretty good in conjunction with a collar. Yes I know what is the best solution but I don't have the budget to split the case.
Any solid long lasting experience with either of these two sealants? Since this is my last time doing this I want to make sure I have the best sealant.
66 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S 11 Speedster |
I have only used Sikaflex in the marine world. It is great for sealing deck cleats and anchor bolts from letting water in. Could it be used in engines? Maybe? I have no idea. We used it because it was the best sealant in the marine environment we were working in. Never bothered to look at the temp range ratings of the ability to stand up to oils, fuel etc...
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Yamabond is actually three-bond if you go to the three bond site you’ll find all the info you need. Been using three bond for many years on various motorcycles et good stuff.
Will it withstand oil pressure?
66 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S 11 Speedster Last edited by bcgreen; 08-27-2020 at 09:35 AM.. |
Yes, all specs at threebond site.
