Camshaft housing sealant? Curil T?
Hi there, just finished one side of the camshaft housing to head install..
Did I make a mistake by using Curil T for the sealant? I was so stoked to
Put it together and I thought I had to use Curil T then looked back in Wayne's
Book, he said loctite 574! $h/t!! Or is that ok? Did some searching couldn't find
Answer. Should I disassembled and redo?
TIA.
Ended up taking the cam housing off the heads, cleaned and installed it back with
The right sealant.
All good.
Old 09-05-2020, 05:18 PM
Glad you re-did it!
That was the right move!
Old 09-06-2020, 02:45 AM
