Is this piston usable
A friend of mine has a set of 2.7RS pistons and one was appearently dropped at some point. Is it usable as-is or is it junk?
Old 09-06-2020, 03:38 PM
Puny Bird
Mark Henry's Avatar
Hard to tell from a pic, sometimes you can fix aluminium by going at it sort of like a paintless dent repair guy. Left over high spots can be smoothed with a small file.
Is it a ding or a divot?
A RS piston I'd try to save.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 09-07-2020, 04:57 AM
safe's Avatar
I would take the gamble....
Before taking a file to it, take a small hammer and try to tap the topside back down. Most om the aluminum is still there it has just been displaced. Then check so its round and that the ring grove isn't tight.
Magnus
Old 09-07-2020, 05:37 AM
That piston is fine. Make sure nothing protrudes outside the circumference of the crown and as has been stated, tap or file down the raised part. Also confirm that the blow didn't close up the ring land, and doubt if it did.
Old 09-07-2020, 06:06 AM
It's a 914 ...
stownsen914's Avatar
It looks slightly raised on the top portion. Maybe on a few thou, but this will narrow the deck height at that one spot. I'd at least want that to be even with the rest of the perimeter around the top of the piston.
Old 09-07-2020, 07:15 AM
Ring land pinched?
Matt B
'73 911E
Old 09-07-2020, 10:06 AM
targa72e's Avatar
The critical part of the piston is top ring land. If it was pinched from dropping or you pinch by hitting with a hammer as others have suggested then it would need to have the top grove re-machined to correct clearance. If ring land is in spec file any high spots from drop and call it good.
john
Old 09-07-2020, 12:14 PM
Thank you all for the replies/advice. I'll measure the top ring gap and go from there.
Old 09-07-2020, 12:21 PM
piston dent
C,mon look at the picture.That was dropped from the side & not the top.The piston to head clearance is a little less.Big deal.Do not touch & the top ringland clearance is fine but measure it anyway.Ciao Fred
Old 09-07-2020, 06:05 PM
Under the radar
Trackrash's Avatar
I would not use a hammer on it. One deformation of aluminum is probably OK. If you do more bending or reshaping you will chance forming a crack.
If it was a wheel I would not hesitate to use a hammer. On a piston, no way. Use a file to even off the top. Check the ring side clearance and call it good.
Gordon
'71 911 Coupe 3,0L outlawed
Old 09-07-2020, 06:34 PM
