burgermeister's Avatar
Thread sealant for cam housing to cylinder head bolts?
Do these bolts get some sort of thread sealant? Bentley does not mention it, but the threads in the head are a through-hole - so the only oil seal is the captured steel washer under the cap screw head.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 09-06-2020, 03:22 PM
Old 09-06-2020, 03:25 PM
Application
If you installed the 574 correctly there should be no leakage.
Bruce
Old 09-06-2020, 04:04 PM
Reuben.L's Avatar
The factory workshop manual does state to apply 574 to the bolt threads.
Old 09-07-2020, 02:18 AM
That, then, would be why they were such a bear to remove ... thanks!
Well, removing & 574-ing one at a time ought not be too bad.
Old 09-07-2020, 02:33 AM
I’ve never seen sealant on the threads of any factory motor I’ve ever taken apart...
Bruce
Old 09-07-2020, 10:59 AM
Reuben.L's Avatar
Bruce
I also found it weird, but i read it during a reassembly on the first 993 engine ive rebuilt just last week. Remember 993s are the only road car engine (that i know of) that use bolts in this area, not studs.
I only sealed the outer bolts as they are through bolts, the inner row are blind holes.
see the installation note 1
Old 09-08-2020, 02:55 AM
prschmn's Avatar
Good picture of the areas to be sealed but missing required sealant around some
of the holes-remember that some of the studs are inside the valve cover and should have sealant as well.
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 09-08-2020, 03:54 AM
