@reimaginedcoachwerks
building a 1500 awhp 8,750 rpm turbo motor
i was fortunate enough that one of my great friends and mentors was willing to do a collaboration on a project that i am currently working on. it is a 996tt widebody car that is still awd and is being widened 8" in the rear and 4" in the front. it has received suspension components from ERP and JRZ, a built trans and this motor and several carbon fiber parts.
I drove out to AZ to lean on my good friend John Bray at Evospec. he was kind enough to allow me to use his shop to assemble two motors in a matter of 3.5 days in his shop all while he and his amazing team did their thing. i could have done it at my shop, but when he hinted that i could come "hang out" with him while we both did our own thing i jumped at the opportunity!
the two motors i built while there were both over 1,000 hp. one was a 1250 awhp motor with his rods, pistons, 997 tt crank, custom headstuds, stage 1 heads and cams that was for a customer that bought a turbo that was supposedly built already. Although we soon found out that when people try to drill a case for bigger headstuds and assemble these motors in their garage bad things happen... like a bent rod, bent crank, blown head gasket and a cracked case!
the second motor is going in one of the shop cars and received all that evospec offers. their custom rods, custom pistons, 4.0l stroker crank, custom bearings, custom oil pump, custom headstuds, stage 3++ heads and cams with the valvetrain to rev safely to 8,750 rpms.
i was working diligently as to not wear out my welcome by getting in the way, or wasting too much time taking photos so there are not as many pics as i usually take to provide to customers for the above mentioned reasons and it is not a customer car.
Old 02-01-2021, 05:09 PM
here are a few pics of the parts out of the damaged motor.
Old 02-01-2021, 05:17 PM
Old 02-01-2021, 05:18 PM
i doubt this "custom cam" had anything do with why it was impossible to control one bank when we had it on the dyno...
this car came from a very well know forum member and was completely misrepresented to the new owner. really sad to be honest. the transmission that was supposedly "built" was so worn out that the only usable part was the case...
Old 02-01-2021, 05:32 PM
Puny Bird
Mark Henry's Avatar
WOW! that's brutal...Can you get a single rod made from Paulter?
They broke a saddle web? How do you even do that???
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 02-02-2021, 03:51 PM
Try not, Do or Do not
Henry Schmidt's Avatar
That rod tells you exactly why you never see the mention of an X beam in a discussion on the strongest racing rods.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-02-2021, 04:20 PM
i will post more pics later this week, but henry is right! which is why we went with the custom carrillo rods that are exclusive to Evospec for 1,000 wheel hp cars on both cars.
Old 02-02-2021, 09:05 PM
well when you attempt to drill your case with a hand drill to install larger diameter headstuds what you get are headstuds that are NOT perpendicular to the case. fasteners use friction to stay fastened. when you have a stud that is installed at an angle you have a limited amount of contact all focused on one side vs 360*. when i took the valve cover off 2-3 headstud nuts were no longer installed, 5-6 were hanging on by a few turns and the studs that had any torque left were anywhere from 45 ft lbs to 115 ft lbs.
obviously i was not involved in the assembly of this motor as the previous owner did it himself before selling it to my customer; therefore i do not know what kind of tq wrench was used, if one was even used at all.
the car made 1060 wheel hp and had way more but with the camshaft damaged we were unable to keep that bank manageable with the vario lift cams. to get the number we got we had to lock the cams down.
anyway, it is behind us now as we are waiting on the new trans to come back from CMS (the previous owner must not know that porscehe's are not drag cars!) to put it back together and retune.
Old 02-02-2021, 09:13 PM
otto_kretschmer's Avatar
any idiot can break an anvil with a rubber mallet
Old 02-02-2021, 11:33 PM
3.6 race engines have been breaking the # 7 main webs for 20+ years. I ended up with a couple of POC race cases that looked the same....The casting will even crack where the reinforcement meets the outer case. Newer cases are redesigned for additional reinforcement.
Henry Schmidt
Ph: 760-728-3062
Old 02-03-2021, 07:57 AM
the cases got shuffle pinned and boat-tailed. custom valves. custom oil pump. coated pistons and bearings. and case and heads machined, not hand drilled, for bigger evospec headstuds.
Old 02-14-2021, 07:54 PM
here is a peak at the stage 3+ heads.
these are the stage 1 heads.
Old 02-14-2021, 07:55 PM
here i am assembling the 4.0l stroker crank. how we had John and Larry assembling their shop motors and my brother and me assembling my shop motors in one clean rooms was a sight to see!
Old 02-14-2021, 07:57 PM
here is my brother helping with the second 1250 hp motor.
setting the timing with the man himself giving advice.
Old 02-14-2021, 08:00 PM
Cairo94507's Avatar
Amazing!
'71 914-6 #0372
'17 Macan GTS
Old 02-15-2021, 11:06 AM
