TRW Valves - Okay to use on a rebuild?
Valve Stem Oil Seal - which is the best to use?
Thanks in advance. |
Viton will seal the best.
I prefer the Teflon because they let a little more lubricating oil down the guide and prolong the guide and stem life. (And TRW is the original supplier of the valves to Porsche.) |
But I see a lot of people saying avoid the TRW valves. Should they be used?
I used to have problems with them, the stems would be nicked up but the past year have not had a problem. Like any new part, look it over before use.
| All times are GMT -8. The time now is 01:18 PM. |
