TRW Valves - Okay to use on a rebuild?
Valve Stem Oil Seal - which is the best to use?
Thanks in advance.
Old 09-20-2020, 03:14 PM
PRO Motorsports
Tyson Schmidt's Avatar
Viton will seal the best.
I prefer the Teflon because they let a little more lubricating oil down the guide and prolong the guide and stem life.
(And TRW is the original supplier of the valves to Porsche.)
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 09-23-2020, 04:48 PM
khamul02's Avatar
But I see a lot of people saying avoid the TRW valves. Should they be used?
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 02-15-2021, 07:57 AM
abit off center
cgarr's Avatar
I used to have problems with them, the stems would be nicked up but the past year have not had a problem. Like any new part, look it over before use.
______________________
Craig
G2Performance
Old 02-15-2021, 08:12 AM
