Emo993's Avatar
Engine Test Run
Engine builder brain trust. Bought a long block eight years ago, said to be rebuilt. 2.2L E with S pistons and cams. Had John Dougherty grind new Mod Solex Cams since the engine still has E heads...All good. Last year after new cam timing/rocker etc. did a leak-down and all cylinders could only come up to 70%. Good thing at least all the same.
I had mention this on an earlier post and most said leak-down number won't say much at this point.
Now, finally ran the engine on a test stand to brake-in cams and see what I have. I also have new PMO's, S distributor, MSD ignition. Ran great, no leaks, carbs adjusted, brake-in oil 20-50 Valvoline. Did leak-down after a half hour running (2000 rpm). Nice, four cylinders now at 4% and two between 12 and 14%. Not bad considering I was at 70% and still no Load being added. Now the big question, the drained oil looked like ****, looked like lots of metallic. Oil drain plug only had the average little amount of smudge. Why does the first oil look so funny. Thanks, Mark
1974, 914-6 GT Tribute
2007 Cayman S
1998 993 Carrera S, speed yellow (Yellow Bird) gone but not forgotten.
2017 Golf Sportwagon 4motion
Exclusive source for the 914 Umbrella and Service cover
Old 09-24-2020, 01:16 PM
As long as the metallic flakes are not chunks then you're fine, totally normal. I normally see what looks like tiny metallic splinters the first oil change, which I always do after breaking in the rings. I stick with non-synthetic until at least 500-600 miles, but that first oil change is always after first running with some load, say 50-100 miles. As for the cylinders with some 15% leak, where from? If from the valves, more running may or may not resolve.
No physical quantity completely explains its own existence
Old 09-24-2020, 05:51 PM
VFR750's Avatar
Cold, never run, engine leak down? Only asking for a bad answer. Rings are not seated.
After running the oil has some wear, rings breaking in, hence some shiny stuff.
Isn’t break-in lube typically dark grey. That gets flushed out.
You may have a problem, but until the rings seat you will have more leak down.
Where is the leakage going? Out the exhaust? Out the intake? Into the crankcase? Or worst scenario: between the head and cylinder?
Need more data.
Old 09-24-2020, 05:53 PM
Emo993's Avatar
Thanks Ivporschepilot and VFR750, and the leak is from the rings on the two cylinders (engine breather). Best, Mark
2007 Cayman S
Old 09-25-2020, 06:35 AM
