Cam removal
2.0 L
Can I remove the cams by backing off the rockers.
Lyndon
Old 09-22-2020, 10:31 PM
No.
Old 09-23-2020, 08:21 AM
Pull the rockers
Bruce
Old 09-23-2020, 08:49 AM
Lyndon
Old 09-23-2020, 02:04 PM
Emo993's Avatar
And if your going to replace the cams you need to have the rockers reground for best results.
1974, 914-6 GT Tribute
2007 Cayman S
1998 993 Carrera S, speed yellow (Yellow Bird) gone but not forgotten.
2017 Golf Sportwagon 4motion
Exclusive source for the 914 Umbrella and Service cover
Old 09-24-2020, 12:45 PM
Im just going to revisit my squish after a recent engine rebuild. I need to.adjust the valves and oil change. So why not pull the engine. Its just a few gaskets.I was never happy with 1.25 mm shims. Will just have to wrestle with the weight of the complete head assembly.
Lyndon
Old 09-24-2020, 04:26 PM
VFR750's Avatar
Pulling off the assembled heads with cam and rockers installed is fairly common practice. Especially if you are doing the tear down for a different reason. Like checking cylinder shims.
Old 09-24-2020, 04:57 PM
Also I can have look inside after my run in.
Lyndon
Old 09-24-2020, 05:05 PM
