One head is 0.005 inch (0.125mm) lower than the other 2
I have a 72 911S engine with one head that is just a tad lower than the other two by 0.125mm. Is there any possibility of damaging the cam if I use it that way?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 10-01-2020, 05:57 PM
.0049" is a lot . I would think that will cause too much interference in the cam tower .
What makes a well built 911 engine is the art of getting all of the measurements in sync .
I would not allow that measurement to stand in one of my builds .
I hope this helps
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 10-02-2020, 01:45 AM
abit off center
cgarr's Avatar
How are you measuring? Together on the engine? could be the case, cylinder or head that's off?
______________________
Craig
G2Performance
Old 10-02-2020, 03:32 AM
I remember a number of .003'' as the limit, but depends on how worn out are the cam shafts and housings. As stated above, in which piece does the problem lie. What ever, you need to fix that. Bows the housing, creates odd stresses and oil leaks.
Old 10-02-2020, 06:32 AM
JoeMag's Avatar
i set them on a cylinder and measure to the cam tower sealing surface using a dial indicator. you don't get absolute thickness, just difference.
if that is really the case, you could get a 0.005" base cylinder shim for that head.
Old 10-04-2020, 06:57 AM
Another option is to machine the remaining cylinder head mating surfaces so they all match. 0.0049” is barely renewing the mating/sealing surface. You also get a very slight bump in compression ratio. I’ve had all heads milled 0.040” to increase the CR, but you also have to take into consideration valve-to-piston clearance, valve lift, cam timing and any other “stack” mods (crankcase spigot, cylinder height).
Sherwood
Old 10-04-2020, 01:13 PM
