Oversize Piston ring replacement vendor
Howdy been a while. Health issues, better now
Ring Gap Confusion
Getting back to my first time 79SC 911 3.0 nothing modified, engine rebuild. I had the cylinders measured/honed by local Porsche guy, Said that cyl looked great
Checked ring gaps on my new std bore Goetze rings
All three rings look to me to have too large gap. 0.43
The Dempsey book range is 0.15 to 0.30
Looks like I will need to find a vendor for over size rings.
I don't mind filing to fit
Tks Gents
ed
Old 10-01-2020, 02:40 PM
Glad to hear your doing better.
I would check with Pelican user Henry Schmidt or one of the other well know shop owner contributors here on Pelican Parts.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
https://supertecperformance.com/
Old 10-01-2020, 03:13 PM
Ollies930's Avatar
Henry is awesome. He has a great stock of unusual stuff, but If he does not have what you need, he will know where to get it.
Old 10-01-2020, 10:34 PM
flyingjay's Avatar
I've used Grant piston rings, they have every size imaginable.
Old 10-02-2020, 09:01 AM
It's a 914 ...
stownsen914's Avatar
I believe Total Seal also makes about everything you could want. Note that they make conventional rings (I used to think of them or gapless rings). I just ordered a set for my rebuild that will have CP custom pistons.
Old 10-03-2020, 04:14 AM
safe's Avatar
He honed them??? I hope he just cleaned them with scotch brite or something.
Magnus
Old 10-04-2020, 03:05 AM
It's a 914 ...
If they're nikasil, it's valid to hone - not to increase the bore like you might do on an iron liner, but to get some texture in the surface.
Old 10-04-2020, 04:07 AM
If I increased the “texture” of my Nikasil cylinders, I would want to check them for surface roughness with a profile meter. Nikasil is so hard that if you get it wrong and have the cylinders too rough, the rings wear out very quickly and the cylinders stay rough. Not like typical cast iron where the cylinders start rough and smooth out as the new rings seat.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 10-05-2020, 06:05 PM
safe's Avatar
That is my thinking too, Nicasil is to hard to "wear in". On my 3.6 rebuild I cleaned the "glase" off with Scotch Brite and WD40, that gave me a duller finish. Seemed to be the safer way for someone lacking a RA gauge.
I think there was a lengthy thread about Nicasil and RA here somewhere....
Magnus
Old 10-05-2020, 11:06 PM
It's a 914 ...
To be clear, if you hone a nikasil cylinder, it would be smart to leave it to pro with experience honing nikasil (and ideally a way to measure RA). The OP mentioned having his done by a pro.
Old 10-06-2020, 04:09 AM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Glad to hear you are better. Something is not right with this picture. New Goetze std rings in a std bore will end up with about .015" end gap. Seems like the bore is not std, hard to do on a Nikisil cyl. Further investigation is required.
I agree with the concerns voiced re "honing" Nikisil. Give Total Seal a call. They have excellent customer service and you can actually talk to a rep.
1986 Targa Guards Red
2021 MT09 SP
Old 10-07-2020, 06:29 AM
