I am my 911's PO
'78 SC's Avatar
twin plug ignition: 12mm or 14mm spark plugs
I'm in the process of getting a set of heads bored and tapped for dual plug ignition. I was under the impression 12mm is the standard for a second plug, but a quick search suggests 14mm is a viable alternative. Is this something that has changed over time, or is 12 mm still the way to go?
12 mm spark plug
Pro: less reduction in compression ratio
Pro: retain more mass in the head (strength and heat capacity)
Pro: avoid interference with head stud hardware
Con: reduced selection of spark plugs
14 mm spark plug
Con: may interfere with stud hardware (does using 5/8" drive spark plugs fix this?)
Pro: full selection of spark plugs
Pro: same dimensions as upper plug (same fit for COPs, boots, etc.)
What other reasons are there to select one over the other? My machinist has experience machining the heads for 12mm plugs.
Thanks,
Old 11-29-2020, 12:14 PM
Slippery Slope Expert
Steam Driver's Avatar
One reason I have heard for using 12 instead of 14mm plug holes when dual-plugging is to leave more “meat” in the head between the valves, for structural reasons.
I have no personal experience with this however.
“As new technologies become indistinguishable from magic, and I can no longer tinker, the magic goes away for me.”
Old 11-29-2020, 01:24 PM
I am my 911's PO
'78 SC's Avatar
Strength is an issue. Apparently heads manufactured for race engines have used 12mm for both upper and lower plugs to retain as much metal as possible.
More discussion here.
Old 11-29-2020, 01:57 PM
12mm to avoid interference with head stud hardware. I went with 12 and still had to turn down my socket slightly in the lathe to get it firmly onto the lower plugs
80SC (ex California)
Old 11-30-2020, 03:49 AM
It's a 914 ...
stownsen914's Avatar
I believe the factory used 14mm plugs on production 3.6 heads? How'd the get them to fit?
My 3.5 has 12mm lower plugs, and yes they are a tight fit (no barrel nuts on the studs right next to the plugs).
Old 11-30-2020, 05:39 AM
Try not, Do or Do not
Henry Schmidt's Avatar
14mm work fine. I have never seen a failure based on this modification.
The compression loss is minimal but accurately dimensioning your engine will allow you to order your pistons to compensate for the chamber volume change.
One cure for head stud nut clearance is Supertec head studs. They offer improved head to cylinder stability,greatly improve engine assembly and the nuts offer clearance for lower spark plugs.
https://www.pelicanparts.com/More_Info/SPTCHSK1.htm?pn=SPTC-HSK-1&bt=Y&fs=0&SVSVSI=911M
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-30-2020, 06:02 AM
Racer
winders's Avatar
The 964 and 993 engines do use 14mm plugs top and bottom. The Xtreme heads in my race engine use 12mm plugs top and bottom. Of course, with the heat and power my race engine creates, you want all the material you can get in the head.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 11-30-2020, 09:31 AM
targa72e's Avatar
964 and 993 use different head stud nut than the allen's used on earlier engines. 964 head nut.
Head stud spacing is also slightly wider. so a little more clearance.
john
Old 11-30-2020, 12:22 PM
I am my 911's PO
'78 SC's Avatar
I had a parallel discussion with Al Kosmal (x-faktory) that cleared up several issues for me. Based on this, I elected to go with the 12mm lower plugs. One consideration is my machinist's experience with 12mm plugs.
Here are Al's comments (by permission):
... The Bosch COPs mate to spark plugs with the smaller diameter ceramic insulation. This smaller diameter insulation is available with 14mm threads or 12mm threads. Example below.
The 3 plugs in the pic below are from left to right
NGK BP6ES (14mm thread with large diameter insulation) will not fit the Bosch COPs
NGK BCPR7ES (14mm Thread will smaller diameter insulation) Fits the Bosch COPs
NGK DPR6EB (12mm Thread with smaller diameter insulation) Fits the Bosch COPs
I just had those on the shelf...you would need to match the heat range top & bottom.
The 2nd pic shows the 14mm w/small diameter insulation installed in the COP
So, if your heads are tapped 14/14 or 14/12, the smaller diameter insulator, that mates with the Bosch COPs is available.........
I typically get my heads rebuilt by Craig Garr and he taps the lower plugs ports at 12mm...so I use 14mm top/12mm bottom
However, the Porsche 964, 3.6 engine is tapped 14/14....so i use 14mm top/14mm bottom.
Al Kosmal
the x-faktory
koz@x-faktory.com
RGruppe #669
www.x-faktory.com
Old 11-30-2020, 12:38 PM
john
This head nut won't help the plug clearance issue in the pre-964 heads.
Henry Schmidt
Ph: 760-728-3062
Old 11-30-2020, 12:56 PM
Jeff Alton's Avatar
I'm with Henry on this one.
All twin plug motors we have done are 14mm. Never an issue, and may only see the track. Plenty have been COP, again no issue.
A small bonus is that at plug change time, only one part number.
YMMV
Cheers
www.turn3autosport.com
Old 11-30-2020, 09:08 PM
