-   -   Reference sensor position on clutch - does it matter? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1079168-reference-sensor-position-clutch-does-matter.html)
marlinaness 11-25-2020 04:55 PM
when putting the clutch on, does it matter where the reference sensor is? Should it be at TDC?
marlinaness 11-25-2020 04:57 PM
I actually meant the little set screw on the clutch with respect to the reference sensor itself?
safe 11-27-2020 06:51 AM
Isn't that on the flywheel and not the clutch?
marlinaness 11-27-2020 08:06 AM
of course. You are correct. Was a very late day. thanks. Maybe somebody will know the answer. Seems like it doesn't matter as I never tried adjusting anyways.
safe 11-27-2020 08:35 AM
The flywheel is "keyed", It only fits in one position.
marlinaness 11-28-2020 06:00 AM
thank you so much. best regards.
Marlin
Henry Schmidt 11-28-2020 07:37 AM
I see you found your answer but it's important to inspect the trigger pin for damage.
I have seen machine shops mangle the pin during resurfacing to the point of making the sensor clearance challenging if not impossible to adjust.
I've also seen replacement flywheels missing the pin altogether.
