-   -   Bracket on oil crossover pipe on 3.0SC engine (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1079196-bracket-oil-crossover-pipe-3-0sc-engine.html)
barneytirebiter 11-26-2020 05:05 AM
http://forums.pelicanparts.com/uploa...1606398943.jpg
Hello to this wonderful knowledge base and Happy Thanksgiving...2 pics show oil crossover pipe I have put on my SC motor after installing SSI's
Where/what does the little bracket with hole in it attach to....?
Thanks for the help...
eastbay 11-26-2020 08:36 AM
Put your tin on and you'll figure it out ;)
Henry Schmidt 11-26-2020 08:49 AM
Aftermarket oil pipes fit poorly. After you get it off the stand the pipe can easily be bent into place.
It mounts via a 6mm bolt to the sheet metal where the front and side piece meet.
barneytirebiter 11-26-2020 09:14 AM
Thank you both...that was quite the "A-ha.." moment..the sheet metal has been off this motor since last February, and i completely forgot about it...I'm glad i brought it up here.
mikedsilva 11-27-2020 02:38 AM
I'm glad you wrote this Henry.. I've fitted a few and never had one that seemed to have the bracket in quite the right spot!
MichaelSJackson 11-29-2020 02:22 PM
To be redundant, I had to massage both the pipe during engine install and the flange/bracket. You'll see when you get there. If memory serves, I wouldn't even bother to attach the bracket until trying to connect the pipe.
It's a common complaint.
