Bracket on oil crossover pipe on 3.0SC engine
![]() ![]() Hello to this wonderful knowledge base and Happy Thanksgiving...2 pics show oil crossover pipe I have put on my SC motor after installing SSI's Where/what does the little bracket with hole in it attach to....? Thanks for the help... |
Put your tin on and you'll figure it out
Try not, Do or Do not
Aftermarket oil pipes fit poorly. After you get it off the stand the pipe can easily be bent into place.
It mounts via a 6mm bolt to the sheet metal where the front and side piece meet.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Thank you both...that was quite the "A-ha.." moment..the sheet metal has been off this motor since last February, and i completely forgot about it...I'm glad i brought it up here.
I'm glad you wrote this Henry.. I've fitted a few and never had one that seemed to have the bracket in quite the right spot!
To be redundant, I had to massage both the pipe during engine install and the flange/bracket. You'll see when you get there. If memory serves, I wouldn't even bother to attach the bracket until trying to connect the pipe.
It's a common complaint. Last edited by MichaelSJackson; 11-29-2020 at 03:25 PM.. Reason: add another suggestion |
