-   -   2.7 Rebuild – To bore or not to bore and other questions (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1082219-2-7-rebuild-bore-not-bore-other-questions.html)
draw 06-09-2024 08:06 PM
I tripped over some square tubing on my garage floor, and I decided to make a crankshaft holding fixture.
After about 8 hours of futzing around and $15 in some nuts and bolts, the (semi) final product...
http://forums.pelicanparts.com/uploa...1717987985.jpg
M12 bolt threads into the crank snout and "floats" in the fixture.
5/8" bolt threads into the fixture and the unthreaded portion (can't be seen here) locates in crank.
It's not pretty, but functional. Since I can't find my flywheel right now, this will come in handy for when I start checking clearances and bolting up the rods.
draw 06-09-2024 08:16 PM
Originally Posted by Uwon (Post 12248454)
Amazing work.
Cheers,
Johan
Thanks Johan!
Originally Posted by RobertDurff (Post 12250546)
Those look great! Which kit from EPI did you end up going with?
It's the Insta-Blak 333 Trial Kit.
Originally Posted by iq207 (Post 12252184)
I had not heard of grooving / cross drilling the #4 main journal before. I assume this is to help oil supply to #2 and #5 cyl rod bearings. I have a crank at Marine right now (1 month, no word yet...) from a spun #5 rod bearing so this might be a very good mod for me. It is not in Wayne's book, not in Anderson's book, not much in a google search. Found a few threads here on it with some different search words. Henry at Supertec says he does it on all his cranks. That is gold for me. Gonna do it.
This is a great thread. Thanks.
Honestly, I have no experience with this and I have no idea if it's worthwhile or not. But it made sense to me and since the crank was at Marine, spending $150 seemed like cheap insurance.
draw 01-04-2025 02:19 PM
After a lengthy hiatus, intermediate shaft teardown, inspect, and rebuild, part B...
The first order of business is to measure the intermediate shaft bearings. Bearing #1 (big end) measured within tolerance at 24.980mm and bearing #2 (small end) measured within tolerance at 23.968mm. Okay, good...
When I went to check axial play, there was none. Hmm...Gave some taps to each end of the shaft to seat the thrust bearing and still nothing. Hmm...does the shaft turn smoothly? Nope. So, I set up my dial indicator and measured about 0.040mm of runout. Yikes! Shaft must be bent...?
http://forums.pelicanparts.com/uploa...1736027166.jpg
Since a new intermediate shaft is about $1,200, I decided to see if I could find a decent used one on ebay. Found one for $140...
Bearing #1 measured 24.978mm, which is just barely out of spec by 0.002mm but within the accuracy of my micrometer of +/- 0.004mm. I'm calling it good...
Bearing #2 measured within spec at 23.975mm.
It rotates nicely in the case and it seems to be good, confirming my fear the original shaft was bad. I will tear the "new to me" one apart, clean it, and rebuild it...
icarp 01-05-2025 05:48 AM
Ward , sorry I'm late to the party , it looks like nice work.
Just a note about new timing sprockets , in post 73 the new shinny sprockets have a reputation for being soft or not heat treated correctly.
The correct new sprockets have a grey tone to them .
Just thought I would share this with you
Carry on , VERY NICE CLEAN WORK
Ian
draw 01-06-2025 08:22 PM
Ian
Thanks for the comment, Ian...I appreciate it!
I've read those discussions about the soft sprockets. Hoping, that Porsche would ensure they were up to spec, I bought genuine Porsche sprockets from our host. Appear to be manufactured 3/9/2019?
http://forums.pelicanparts.com/uploa...1736221533.jpg
But me being me, I purchased some HRC files to see if there was a difference.
First up was the original sprocket at HRC40. Scratched...
Next up was the new sprocket at HRC40. Scratched, but not as easily as the original...
Just for fun, I tried to scratch a con rod and it didn't scratch using the HRC40 file.
What to do? Since both sprockets have an HRC less than I can test with my files, I don't actually know which one is harder or softer, but both are less than HRC40. Anyone have an HRC tester to check for an exact number?
Tsubaki suggests an HRC of 35-50 for small sprockets. According one of their tables, HRC30 sprockets have a tensile strength of 138,000 PSI and HRC35 sprockets are 160,000 PSI.
http://forums.pelicanparts.com/uploa...1736222533.jpg
I'm not sure what I'm going to do yet, but I think the genuine Porsche sprockets seem okay.
MoreGAS 01-07-2025 09:23 AM
I'm not sure where you are located but we sourced a local heat treating Co. to do Rockwell C scale testing for us when we want to know how tired various parts are we are considering reusing or putting in to service or that we have welded on (heads) , when race engines are torn down. These were mostly aluminum components- Pistons. I'd call one of them and learn exactly what you are putting in there. Wouldn't be surprised if nice old used parts are a better choice.
Sad that we are at this point even with "Genuine" parts today, the repro parts situation is even more dodgey.
Kevin
GAS Motorsport
draw 01-12-2025 11:01 AM
Kevin
GAS Motorsport
Thanks for the comment, Kevin...I appreciate it!
I sourced a materials testing lab in San Diego that I might take the sprockets to for HRC testing. They charge $150 for up to six parts.
Before doing that, I ordered two sprockets made by Rauch & Spiegel that claim that they "are the good ones, made in Germany for us from the proper material with the proper heat treatment." However, I was skeptical of this claim.
Rauch & Spiegel on the left, new genuine Porsche on the right...
http://forums.pelicanparts.com/uploa...1736707684.jpg
I didn't get a "real" scratch on the Rauch & Spiegel sprocket until I used the HRC65 file. The original part came in at less than HRC40. I think this confirms their claim that they are properly heat treated.
This settles it for me. I'm going to use the Rauch & Spiegel sprockets.
draw 01-19-2025 12:44 PM
Got the case hardware yellow zinc plated. Thanks to this post by ErrorMargin (https://forums.pelicanparts.com/porsche-911-technical-forum/1164377-1st-batch-parts-back-zinc-plating.html#post12285151), I used Cadillac Plating.
Originally Posted by ErrorMargin (Post 12285329)
I used Cadillac Plating in Orange, CA.
I think it was $60 for the batch and took about 3 days.
No issues and the parts came out great!
https://www.yelp.com/biz/cadillac-plating-co-orange
They did an ok job on the parts that weren't too crusty. I had to chase the threads on everything because they plated over some of the rust. If I used them again, I would do a "pre-clean". But satisfactory for $100 for everything.
http://forums.pelicanparts.com/uploa...1737316355.jpg
Got everything sorted using calipers and a combination of photos with handwritten notes with stud dimensions from the parts manual.
All installed! I didn't have anything left over, which is unusual for me, but I was extremely methodical...
Also checked to make sure the piston squirters were working. Had a little trouble with the squirter for the #2 piston (not pictured), but got it cleared.
draw 01-26-2025 11:44 AM
Being a doofus leads to an expensive intermediate shaft saga...
Back in post #83, I thought that my intermediate shaft was bent due to excessive runout, and it wouldn't turn smoothly in the case. I bought a used one off ebay, which measured in spec and turned smoothly. When I went to check axial play, there was none. So, like with the first shaft, I decided to tap on each end to seat the thrust bearings. Recheck...Argh! Now it won't turn!
Turns out that my "tapping" bent the flange inward, causing the binding.
Intermediate shaft #1...
http://forums.pelicanparts.com/uploa...1737918326.jpg
Intermediate shaft #2...
While I admit to being a doofus on a regular basis, I am experienced in the use of a hammer. I was a carpenter in my youth, before nail guns were commonplace, and have driven hundreds of thousands of nails. This may have actually been my downfall because I wasn't expecting the flange to be so soft and my usual hammering force was too much.
All of my fiddling marred the bearings a bit...
After learning from my mistakes, I bought another ebay special. Cleaned it up a little and found some pitting on the journal. Argh! Not using this one...
And the aftermath...
Intermediate shafts: $700 (1 original and 3 ebay)
Bearings: $300 (Glyco and Porsche)
Total cost of being a doofus: $1,000
draw 01-30-2025 04:26 PM
Moving on with the intermediate shaft teardown, inspect, and rebuild, part C...
Measured the 0 gear with two 4.5mm pin gauges. Came in at 136.97mm and the minimum spec is 136.5mm. On to the next step...
http://forums.pelicanparts.com/uploa...1738277706.jpg
Installed new Porsche intermediate shaft bearings. End play came in 0.042mm and the minimum spec is 0.040mm. On to the next step...
Prepared the shaft with some studs to guide lining up the holes...
Heated the gear in my thrift store bearing and gear heater (AKA toaster oven)...
After assembly (no pics), installed the intermediate shaft and crankshaft to measure backlash. Came in at about 0.135mm (ignore the rev counter) and the maximum spec is 0.049mm. Argh! Not on to the next step!
I was taught by the "old timers" to always change gears in pairs and the Porsche Technical Specifications booklet says to "replace intermediate shaft gears and crankshaft gears in sets only." Off to order a new 0 gear for the intermediate shaft and a new 0 gear for the crankshaft.
Richey 02-01-2025 08:51 PM
draw , you should follow PeteKz's advice for a deck height of .75 to 1 mm for better squish and chamber turbulence . Machine the piston tops instead of adding cylinder base shims . From my experience this is a difference you can notice when driving .
draw 02-02-2025 04:47 PM
Thanks for the comment, I appreciate it!
Here's where my lack of engine building experience definitely shows. I've spent a lot of time juggling the different options, and I think I've settled on using a 1.25mm shim, which puts my calculated deck height at 1.04mm. Pretty close to the 1.0mm standard spec. I've chosen this as a tradeoff to keep my compression ratio (about 10.1, calculated) in a decent range for street use with 91 octane premium gas and twin plugs. If I was more experienced, I would feel more comfortable with stacking shims of varying thicknesses to reduce the deck height a little. I did seriously consider stacking a 1.0mm and a 0.20mm shim, which would put my deck height at 0.99mm, resulting in a compression ratio of 10.15. But I'm concerned that stacking these two shims would lead to a leak. Also, I'm running the LN cylinders without a head gasket/sealing ring and I'm trying to keep everything as stable as possible.
Anyone with experience stacking shims care to chime in?
silverlock 02-02-2025 06:23 PM
I would expect twin plug at 10:1 static on 91 to be safe, especially if you tune for it and don’t advance ignition too far.
What cams are you planning to run and (thus) what is your dynamic compression ratio? If you run a decent amount of overlap + lift your DCR will probably be more like 7.5:1 (approaching ~8 at higher RPMs) and thus plenty of margin.
draw 02-02-2025 07:10 PM
Moving forward after my saga...
I ordered a new intermediate shaft gear from Pelican for $270 and a NOS crankshaft gear from Aase for $360.
Pulled the gear stack off the crankshaft and reinstalled with the new gear.
http://forums.pelicanparts.com/uploa...1738544721.jpg
Rebuilt the shaft with all new gears and used Loctite 574 on the end plug.
Checked backlash, which came in at 0.023mm. Much better!
Checked end play on the crankshaft. Minimum spec is 0.110mm (I believe) and it came in at 0.123mm...
And "bob's your uncle"...
Test fit the new oil pump. (I know the pump is overkill, but I got a good deal on it...)
draw 02-09-2025 06:09 PM
Moving on to prepping the rods...
I had Ollies recondition the rods and resize the big end with ARP rod bolts. Need to break them down and give them a good cleaning...
http://forums.pelicanparts.com/uploa...1739150719.jpg
I am using the "stretch" method for the rod bolts instead of relying on a torque value.
And, I've discovered that there are several differing techniques to measuring. Taking inspiration from Tony's post (https://forums.pelicanparts.com/911-engine-rebuilding-forum/1070821-stretch-gauge-beginner-question.html#post10994234), I came up with my own technique...
I've decided to set the dial indicator to a known value of 2.750 inches by using two gauge blocks. This will allow me to measure and record the pre-stretched length with a repeatable method.
Using this bolt as an example, it measured 0.009" from the baseline of 2.750", so the length is 2.759". When I go to install the rods, I can just add the stretch value to each bolt's original value. For example, 0.009" + 0.0095" = 0.0185 on the gauge.
On to cleaning...
LukasM 02-14-2025 02:28 AM
Hey Draw,
You are doing great work especially for a non-pro, with meticulous attention to detail!
I am learning a lot as I am following along, thanks for sharing your journey with us. I have an engine rebuild coming up myself and the note file with tips and tricks is getting longer and longer. http://forums.pelicanparts.com/support/smileys/clap.gif
Cheers from Austria,
Lukas
fanaudical 02-15-2025 08:22 AM
That pump isn't overkill - I have the same pump in my 2.7. You'll appreciate the extra flow, oil pressure, and cooling (assuming you're fitting an external cooler). It's cheap peace of mind.
Great attention to detail!
draw 02-15-2025 12:35 PM
I'm using the DC43x-102 cams from John Dougherty. I should be okay, but I am paranoid of the dreaded "ping" of detonation.
Originally Posted by LukasM (Post 12410646)
Hey Draw,
Lukas
There's no way I would be able to undertake this project without:
  • The collective wisdom of this forum
  • Wayne's How to Rebuild and Modify your Porsche 911 Engine
  • Bruce Anderson's Porsche 911 Performance Handbook
Tony's engine rebuilding class...
Originally Posted by boyt911sc (Post 9872593)
To fellow 911 enthusiasts:
Some one has suggested to me to conduct an engine rebuilding class and to my surprise, there are numerous members showing interest. I have received several PM’s expressing their desires to get into this class. One member offered his large garage but he is 300 miles away from home. So getting the engines, equipment, tools, etc. would require some serious logistic undertaking.
I have a two-car garage/carport soon to be a 3-car parking space. If I park my ‘78 and ‘89 at my son’s residence which is only 7 miles away, there would be ample room to accommodate a small group (5 or less) for engine tear down or engine assembly class...
Tony
YouTube, including:
And especially Kurt at Klassik Automotive Training School. Kurt covers almost everything in the rebuild process and shows how to do things not covered by any book https://www.youtube.com/@klassikats.
I agree with you and the pump was 30% off when I bought it. And, I wanted to have a pump capable of working with a front mounted oil tank and dual oil coolers if I decide to go that route at some point.
draw 02-15-2025 03:01 PM
As I get closer to closing the case, I wanted to know how much time I really have before the Loctite 574 cures. Is it 15, 30, or 45 minutes? Opinions seem to vary widely...
Reading the Loctite TDS, cure time varies due to many factors, including whether the metal is active or inactive. Hmm, since the case is a magnesium alloy, which is "inactive," I thought an experiment was needed...
First, using an old magnesium chain housing as a proxy for the engine case, how long can I leave the 574 sitting there before it hardens? After 1 hour, the 574 was still in a gel state and there was some "shrinkage," but it wiped right off. I did not try a longer timeframe, because I figured an hour is more than enough working time.
http://forums.pelicanparts.com/uploa...1739653495.jpg
Next, I clamped the cover and housing together to test how well it would cure in an anaerobic environment. After an hour, I opened it up and the 574 was still in a gel state (not pictured). I reapplied the 574 and closed it back up to see how things would fare after 24 hours.
After 24 hours, I opened it up and the 574 appears to have cured. The empty spots of 574 seen in the picture were adhered to the other side.
My takeaway is that (1) 574 can sit on the case in open air for at least an hour; (2) on an inactive metal like magnesium alloy, the 574 takes longer than an hour to start curing so I don't need to be in an extreme rush bolting things back up; and (3) full cure probably takes at least 24 hours and probably longer.
I called Henkel's technical support, and they suggested that the SF 7649 activator be used on magnesium. They said that without the activator, it's possible that the 574 may take 24-72 hours to cure or may not cure at all. From my testing, it seems the 574 does cure, and so I will forgo using the activator.
PeteKz 02-16-2025 11:30 AM
It's always good to have more working time, just in case the assembly doesn't go together quickly.
draw 02-16-2025 05:52 PM
Time to measure rod journals and oil clearances...
I measured all of the rod bearing journals. All 6 came in at 51.976mm and the spec is 51.990-51.971. Ok, good...
http://forums.pelicanparts.com/uploa...1739755444.jpg
Surgical cleaning of each rod and the bearings. Torqued them to 50 ft-lbs per ARP spec. (I'll be using a stretch gauge when I bolt them up for real).
I set my micrometer to 52.000mm and zeroed out my bore gauge...
Used bore gauge to measure vertical clearance...
And the results...
http://forums.pelicanparts.com/uploa...1739756114.png
Oil clearance is definitely on the "loose" side. Too loose? Not much I can do about it at this point. Looks like a 20W-50 oil will be required for sure...
draw 02-18-2025 04:16 PM
Time to measure the main bearings and oil clearance...
Measured the main journals on the crank. Spec is 56.990 - 56.971...
http://forums.pelicanparts.com/uploa...1739923672.png
Ok, good. Time to measure the oil clearances...
Inserted bearings into the case...
http://forums.pelicanparts.com/uploa...1739920917.jpg
After putting the case halves together, I realized that I installed the wrong stud. Took it apart and put in the correct stud, then bolted it up and torqued everything to spec.
Installed the extension on my Mitutoyo bore gauge so I can reach all the bores...
Set my micrometer to 57.000mm and zeroed my bore gauge...
And here's where things went south...
Measured oil clearances for #7 at 0.115mm, #6 at 0.132mm, #5 at 0.131mm, and #4 at 0.139mm. Then I stopped...this can't be right, can it? As a crosscheck, I set the micrometer to the size of the journal, zeroed my bore gauge and measured again. Same results. I checked my micrometer against the standard. Still good. Checked the micrometer against a 2.000" gauge block. Bang on. The bore gauge is accurate to +/- 2µm. WTF???
Maybe the case wasn't lined bored correctly? So, I took everything apart, took out the bearings, and bolted it back together. Spec for the case bore is 62.000mm to 62.019mm.
http://forums.pelicanparts.com/uploa...1739923108.png
It's all within spec, but on the "loose" side. The crank journals are in spec, but on the "loose" side. The result, loose + loose = too loose.
Not sure what to do here. Run it? Buy some Calico coated bearings?
Opinions welcomed!
targa72e 02-19-2025 12:26 PM
When you bolted the case together did you have the #8 bearing installed? The #8 bearing serves a important part to align the case halves. I could not get my bore gauge to fit thru the standard hole in the #8 and had to use a old one and machine the opening larger. I got lots of bad measurements until I used the modified #8 for alignment. Just a thought.
john
PeteKz 02-19-2025 01:01 PM
Ward, I was away for a couple weeks and now catching up. I think you are doing an excellent job as a first-timer. In fact, you're being more meticulous in measuring everything than I would, but I've built these engines before.
Those oil clearances are too much. What bearings did you use? New ones? Do you still have the old ones that came out? If so, try assembling with those and see what you get (as a first step, measure the thickness of the old bearing shells versus the new ones). BTW, I am a fan of reusing old bearings if they are not visibly worn and measure within specs because they have already proved themselves in service. Bearings are not supposed to wear in use. If they do, then either oil flow was interrupted or the oil had contamination in it. And, some new bearings have been measured out of spec.
Call whoever did your case work and crank work and talk to them too.
With larger clearances (but within specs), more oil will flow through the bearings. I consider this a good thing, since that's what cools the bearings. Builders of race engines usually shoot for larger bearing clearances for this reason. You also have a larger oil pump, so I think you will have plenty of excess oil flow. FYI, I'm using 5W-30 oil right now and have plenty of pressure with a Turbo pump (also larger capacity) in my 3.0 case. Don't go to 15W-50 unless your oil pressure is low, and then I would be thinking that something else is losing the pressure. Oil pressure should be at least 10psi for each 1000 RPM. A healthy 911 engine will reach 60psi long before it gets to 6000 RPM. If it doesn't, something is wrong.
PeteKz 02-19-2025 01:18 PM
Re stacking base shims: No problem. Use the Three bond stuff recommended on this forum, or the Permatex Mega Gray high-torque sealer. After having some pesky case leaks using 574, I've decided to use the Mega Gray or Three Bond on the case halves on future builds.
draw 02-19-2025 02:41 PM
john
Thanks for the comment, John...I appreciate it!
No, I didn't have the #8 bearing installed, but my case is shuffle pinned, so that should (hopefully) locate the case halves properly.
Yes, for sure!
Thanks, I'm 44% German (Prussian, really) and I try embrace my "meticulous" side. Plus, I really wanted to get into the "nitty gritty" of everything to increase my knowledge.
The bearings are new Glyco and the old ones were trashed long ago. I "miked" the bearing shells, the results are in the following table (mm).
http://forums.pelicanparts.com/uploa...1740003928.png
Yes, I will definitely need to experiment with the oil viscosities. Maybe my GT3 oil pump isn't going to be overkill after all...Ha!
Thanks for the feedback on the shims. I know it's done frequently, but it's not optimal. But it may not matter anyway. I've been agonizing over going with a 1.0mm shim and deck height of 0.79mm. Either way, Curil T2 will be used.
PeteKz 02-19-2025 03:08 PM
I'd go for the deck height of 0,79mm.
Glyco is the brand that had some quality control problems. I know you measured the diameter of the bearing shells installed in the case. I meant to measure the thickness of the shells themselves. Should be few mm, then compare to the old ones, but if you trashed the old ones, maybe you can find some others compare to. Or someone here has those numbers. They may be too thin, which would increase the oil clearance.
draw 02-19-2025 03:18 PM
Since I can be a doofus at times, I wasn't sure of my dial bore gauge'ing skills. Maybe my measurements were erroneous? I confirmed main bearing oil clearances with...Plastigage???
Put a strip of Plastigage on journals 1-7...
http://forums.pelicanparts.com/uploa...1740005410.jpg
Torqued up the case, including the #8 bearing, and the results came out fairly consistent...
The results (estimated when in between sizes)...
http://forums.pelicanparts.com/uploa...1740005934.png
Damn, I was hoping i was going to be wrong. Now what? Search the forum! I came across this post about HM Elliott...
Originally Posted by Ollies930 (Post 9720977)
lvporschepilot, I do not have any personal experience with mag cases, but being .002" out of round would scare the crap out of me and I would probably try to have the case halves skimmed a couple of thou and line bored back to standard round. Probably expensive, but I would avoid the oversized bearings for .25mm oversized line bore at all cost, the oversized bearings (if available are ridiculously expensive, at least on 3.2/3.3/3.6 cases)
Tippy, I do not know the exact prices on the coatings and I do know that the mains would be more, but I had my rod bearings quoted with a double application of the pro stock/top fuel coating and removing the existing standard coating first at around $85 for the set, IIRC. Give them a call, they are very helpful and check out their web site
https://www.hmelliottcoatings.com/
I gave them a call to see what they could do to the bearings. They asked me what type of engine I have. When I said "Porsche," they started cracking up!!! He laughed because they're "doing them all the time now." I guess I'm not the only one with this problem.
Sent the bearings off today to get them double coated with their HM30 coating. This is supposed to take up 0.001" or 0.0254mm, which will get my clearance in the 0.100mm to 0.080mm range. Not great, but better. Now to wait 2-3 weeks for them to come back...
PeteKz 02-19-2025 03:37 PM
Ward, if you already sent them off in the mail, then too late. But I would want to find out why they were so far off in the first place. I don't like to apply band-aids if I can avoid it. I would want a clearance in the .0025" range (.064mm).
Rosco_NZ 02-20-2025 02:43 PM
Another way is to install oversized bearings and grind the crank to suit each installed and measured main bearing. In my case, both case and crank were ‘std’ but outer limits of spec, net result excessive clearance.
draw 03-02-2025 02:14 PM
Got the bearings back from HM Elliott with two coats of their HM30 coating. Total cost was $148.21.
Inserted them into the case and torqued it up to spec.
http://forums.pelicanparts.com/uploa...1740952351.jpg
I checked the clearances with Plastigage and the bore gauge.
They came in tighter as expected, but still on the loose side. The #1 thrust bearing is on the tight side. I was expecting that, too since the case bore was on the minimum spec of 62.000mm.
http://forums.pelicanparts.com/uploa...1740952536.png
I think this is as close as I can get without undertaking some additional machine work to the case or the crankshaft, which I'm not really excited about. I'm moving forward unless someone talks me out of it...
PeteKz 03-02-2025 10:55 PM
I won't talk you out of it. Run it.
draw 03-08-2025 12:50 PM
I wasn't happy about the loose oil clearances for the rods using the Glyco bearings, so I bought a set of ACL bearings.
http://forums.pelicanparts.com/uploa...1741464420.jpg
I swapped out the Glycos and remeasured. While still not "perfect," the clearances have decreased from the 0.090mm range to 0.080mm range.
http://forums.pelicanparts.com/uploa...1741465554.png
With that sorted, I moved on to installing the rods. Even though some people say that rod orientation doesn't matter, I followed this advice...
Originally Posted by Flat6pac (Post 10991697)
Having taken apart many factory assembled motors I face the crank with #8 to my left and the rods pointing towards me and I record the rod numbers, which are all facing up,
That’s the way I reassemble the crank.
Bruce
I torqued the ARP rod bolts to 45 ft-lbs, then went to the stretch gauge. The initial torque gave me about 50% of the stretch I needed, then I took it home with 12-point extra-long box end wrench.
And Bob's your uncle! My homemade crankshaft holder came in extra handy during the bolt stretching process. Also, by premeasuring each bolt and then adding the stretch value, it was easy to hit the desired stretch. I'm glad I followed the advice gleaned from this forum.
Feels good to make progress...onward!
LukasM 03-09-2025 04:22 AM
Hi Ward,
Nice progress indeed, almost ready for case assembly!
And good to hear that the coating helped enough to get the clearances within tolerance. How durable is the coating, compared to regular bearing shells?
What is your view on the case, did Olli's do a good job? I would have thought that they would align bore to the minimum specified size, since wear just opens up the bore over time, and you want to maximize service life. However I'm a novice when it comes to engine building so maybe I'm overlooking something.
Cheers,
Lukas
jkkarrow 03-09-2025 11:28 AM
Nice headers,Fab engine!
Rosco_NZ 03-11-2025 11:08 AM
Seems Ollies bore to spec … my case was STD but on the high side, crank was STD but on the low side .. net result too much clearance.
dedyplay 03-13-2025 12:56 AM
Fabulous engine! Make sure the intake and exhaust ports are well opened!
SiracHaile 03-17-2025 09:47 PM
I had my case align bored and pined by Ollie’s. I measured my clearances with a dial gauge and plastigauge and they were loose .[emoji[emoji638][emoji639][emoji[emoji6[emoji640][emoji638]][emoji640][emoji640]][emoji[emoji6[emoji640][emoji638]][emoji640][emoji640]]][emoji[emoji638][emoji639][emoji[emoji6[emoji640][emoji638]][emoji640][emoji640]][emoji[emoji6[emoji640][emoji638]][emoji640][emoji640]]][emoji[emoji[emoji638][emoji639][emoji[emoji6[emoji640][emoji638]][emoji640][emoji6[emoji640][emoji637]]][emoji[emoji638][emoji639][emoji[emoji6[emoji640][emoji638]][emoji640][emoji640]][emoji[emoji6[emoji640][emoji638]][emoji640][emoji640]]]][emoji639][emoji[emoji6[emoji640][emoji638]][emoji640][emoji6[emoji640][emoji637]]][emoji[emoji638][emoji639][emoji[emoji6[emoji640][emoji638]][emoji640][emoji640]][emoji[emoji6[emoji640][emoji638]][emoji640][emoji6[emoji640][emoji637]]]]]” across all mains. I called Ollie’s about it and they assured me it’s fine. So it’s together and once I get it running we’ll see what the oil pressure is at. But I thought I was the only one looks like it’s common.
Herb_911_76 03-22-2025 03:39 PM
Draw, thanks for your detailed report, very informative as I'm also working on a 2.7. FYI: Previous owner had Dilavar studs on exhaust side. All but 3 Dilavars had snapped while all steelies on the intake side were fine and tight, despite a lot of rust. Novice advice requested: Your bearing trouble has me reconsidering splitting the case. It wasn't leaking, except a bit of sweat around both shaft seals. Are there any pointers that can help me make a decision? I don't know the exact mileage (intermittent odometer), but should be around 80k miles. Cylinders still have cross hash and also Pistons are dead nuts in spec, valve guides are worn... Sorry didn't mean to hijack your thread.
draw 04-06-2025 03:20 PM
The planets finally aligned, and I got the case closed!
http://forums.pelicanparts.com/uploa...1743976626.jpg
I added a very thin schmear of Threebond 1211 to the #8 saddle and inserted the dowel pin before dropping in the crankshaft...
Yes, I will be moving the ground strap!
Celebrated with a German beer...
http://forums.pelicanparts.com/uploa...1743977856.jpg
Onward...
