Good news thay you found it before any damage could have occurred. Good work.
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Easily Confused
So the shaft was offset more toward the thick side of the jousting than the thinner side?
Scott C. '08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65 |
Spent the entire Sunday fixing it. Easy fix once I got there. I did have to remove the oil cooler. Now to triple check valve adjustment since all covers are off. And then a lot of re-assembly. It'll be a least another week before I start it I'm afraid. I work 50hrs/wk and have plans next weekend.... ![]()
I find that very interesting.......
Non User
Any updates? I’d sure love to hear that was your problem and it’s now solved...
Infraredcalvin - AKA Pat '76 Turbo Carrera #311 - Factory LSD, Sport Seats ‘71 914-6 GT 3.4L twin plug track car '75 914 GT clone project '71 914 track car, fresh 2165 FAT motor (for sale soon) |
Noise still there. Son of a dog.
A couple of things that might help. You could possibly narrow it down to one cylinder by grounding out the plug wires one at a time and listen for a change. If you have a stethescope or piece of heater hose, start listening around to try to narrow down the location.
#6 piston pin retaining clip missing. Pin walked. Cylinder ok but Piston not.
Wanted 1 Mahle 90mm 2.7 10.3:1 Carb/Mechanical Piston and pin. |
gosh.. got a pic of the damage? wonder where the circlip is...
Easily Confused
Wow, that is terrible. Sorry to hear this.
Good luck on the piston search.
Have you removed the vacuum line from the distributor. The vacuum cans for MFI are different to accept the pulses and a CIS can for example will clack like yours. Ask me how I know.
Never mind looks like vacuum can is disconnected. |
Come on, Gled. Try to keep up. LOL
Ken 1986 930 2016 R1200RS |
Sherwood |
Tore engine completely down. Split case. Did not find clip.
Going back together with JE 10.5:1 New set of Mahle $6k just too much money. Pistons have changed in metallurgy of the years. So finding a single NOS or good used 10.3:1 from the 70's or 80's just not gonna happen. Paying a professional now, cant risk anything again, plus I work 50hr/wk just don't have the time. Sucks, but its in good hands, I trust the guy. |
Speedy, sorry about your bad luck. Hope you get it sorted asap.
I would also like to kmow more about this, I have a 3.0 that makes quite a lot of low rpm clacking and shutoff clatter:
1981 911SC restomod "Minerva" 2004 Boxster S 2021 Cayman GTS 4.0 manual "Olive" 2014 Cayenne GTS V8 (wife's lover) The slope is not slippery; in fact it is entirely frictionless. |
Speedy914 - Wow, I am so sorry read and see this happen to your engine. But it will be back together and in the car soon.
I dreaded the start-up on my fresh engine after it sat for about 3.5 years before being fired up. We were flipping a coin to see if it would be OK once fired. Real nail biter for me.
'71 914-6 #0372 '17 Macan GTS |
May I ask if your pistone were 2.7 or 2.8?
i bet the missing circlip is on your workshop floor somewhere....
