Originally Posted by BURN-BROS View Post
I just noticed the video, That sounds like Valve lash.
I would look at the rockers carefully and make sure the shafts are in the correct positions.
Originally Posted by 911pcars View Post
Here's another. Rocker arm shaft only partially supported = valve noise.
removed exhaust valve cover were noise seems loudest. #6 exhaust rocker shaft is incorrect. Towards the thick side in the carrier not the thin side. Its tight. I guess I f'd up during assembly. Now to fix it and check all the others. Hard to believe all that noise just from that? A ***** to get to it. A 914-6 so suspension id pretty close to that area. Although I think I can remove the oil cooler and get it. Looks like another Sunday in the garage on my back...
Old 02-27-2021, 05:35 PM
Good news thay you found it before any damage could have occurred. Good work.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 02-28-2021, 12:31 AM
Easily Confused
dtxscott's Avatar
So the shaft was offset more toward the thick side of the jousting than the thinner side?
Scott C.
'08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65
Old 02-28-2021, 09:49 AM
Correct. Seems like a lot of noise from just that, but I had 2 other people (other then this forum) that thought rocker shaft loose or alignment was the sound. I checked them all of course, its the only one wrong (my fault of course)
Spent the entire Sunday fixing it. Easy fix once I got there. I did have to remove the oil cooler.
Now to triple check valve adjustment since all covers are off. And then a lot of re-assembly. It'll be a least another week before I start it I'm afraid. I work 50hrs/wk and have plans next weekend....
Old 02-28-2021, 12:52 PM
nene's Avatar
I find that very interesting.......
Old 03-07-2021, 08:53 AM
Non User
infraredcalvin's Avatar
Any updates? I’d sure love to hear that was your problem and it’s now solved...
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
‘71 914-6 GT 3.4L twin plug track car
'75 914 GT clone project
'71 914 track car, fresh 2165 FAT motor (for sale soon)
Old 03-09-2021, 08:07 PM
Noise still there. Son of a dog.
Old 03-10-2021, 02:24 PM
A couple of things that might help. You could possibly narrow it down to one cylinder by grounding out the plug wires one at a time and listen for a change. If you have a stethescope or piece of heater hose, start listening around to try to narrow down the location.
Old 03-10-2021, 03:23 PM
Yep. I have an engine ear (battery powered headphones with stethoscope) Can't seem to pinpoint area. I will try pulling plugs wires and see if change. Thanks.
Old 03-10-2021, 03:32 PM
#6 piston pin retaining clip missing. Pin walked. Cylinder ok but Piston not.
Wanted 1 Mahle 90mm 2.7 10.3:1 Carb/Mechanical Piston and pin.
Old 04-13-2021, 03:56 PM
gosh.. got a pic of the damage? wonder where the circlip is...
Always learning.
Old 04-14-2021, 04:57 AM
Easily Confused
dtxscott's Avatar
Wow, that is terrible. Sorry to hear this.
Good luck on the piston search.
Scott C.
Old 04-14-2021, 05:20 AM
Have you removed the vacuum line from the distributor. The vacuum cans for MFI are different to accept the pulses and a CIS can for example will clack like yours. Ask me how I know.
Never mind looks like vacuum can is disconnected.
Old 04-14-2021, 07:35 AM
Oh, that blows. That...blows.
I’d worry about that clip too. Whole other deal splitting the case though.
Come on, Gled. Try to keep up. LOL
Ken
1986 930 2016 R1200RS
Old 04-14-2021, 05:06 PM
Retrieving the clip (or what's left of it) will determine the extent of the repair. If lucky, it will be in one piece on top of the screen or in the bottom of the case. It's magnetic and maybe retrievable (easier in a non-ferous case). If you can, show us your piston for further autopsy. It's curious the cylinder escaped injury.
Sherwood
Old 04-14-2021, 10:33 PM
Tore engine completely down. Split case. Did not find clip.
Going back together with JE 10.5:1
New set of Mahle $6k just too much money.
Pistons have changed in metallurgy of the years.
So finding a single NOS or good used 10.3:1 from the 70's or 80's just not gonna happen.
Paying a professional now, cant risk anything again, plus I work 50hr/wk just don't have the time.
Sucks, but its in good hands, I trust the guy.
Old 04-21-2021, 03:12 PM
evan9eleven's Avatar
Speedy, sorry about your bad luck. Hope you get it sorted asap.
I would also like to kmow more about this, I have a 3.0 that makes quite a lot of low rpm clacking and shutoff clatter:
Porsche made a batch of 3.0 liters that had excessive crank endplay and exhibited a knock below 900 rpm
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 04-26-2021, 01:32 PM
Cairo94507's Avatar
Speedy914 - Wow, I am so sorry read and see this happen to your engine. But it will be back together and in the car soon.
I dreaded the start-up on my fresh engine after it sat for about 3.5 years before being fired up. We were flipping a coin to see if it would be OK once fired. Real nail biter for me.
'71 914-6 #0372
'17 Macan GTS
Old 04-26-2021, 02:18 PM
May I ask if your pistone were 2.7 or 2.8?
Old 11-28-2024, 11:46 AM
i bet the missing circlip is on your workshop floor somewhere....
Always learning.
Old 11-28-2024, 11:51 AM
