The air path for absorbed and rejected heat from these coolers is directed into the air cooling stream instead of dumping heated air outside the vehicle. This raises the temperature of the ambient temperature air flow, not ideal. Sherwood |
Try not, Do or Do not
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Henry, understood and acknowledged. It’s also a major project to install a front cooler with its plumbing in the tight space constraints.
The 9 Store
All used parts sold as is. |
mepstein hits the bullseye as expected. If you are going to add an oil cooler to a 914, do it the way the factory did. This is the way I did mine along with the PMS oil cooler and thermostat. The car never overheats and I am running a 3.2 in the CA Bay Area where we see 105 degrees in the summer with lots of traffic.
'71 914-6 #0372 '17 Macan GTS |
Henry,
So the Rx 7 cooler has a built in TStat? Any reason this would not work plumbed in to the scavenge side of the original oil system? Seems that would be a most simple system. Scavenge outlet plumbed into this cooler with built in thermostat controlling flow to the cooler. Agreed that this cooler location is not optimal, but my gut instinct engineering feel is that increases in charge temp would be small and oil cooling effective. |
By using a sandwich plate as I described, the entire project is a bolt on accessory. Modifying the deck lid is the only permanent alteration. That's why sourcing another deck lid makes sense. Paint it to match, save the original and you win. The 914-6 is climbing in value.....mess with it at the cost of originality and resale value.
For a full flow cooler, the inlet and outlet ports are typically replaced by larger weld-on adapters (e.g. AN-12, -16).
Puny Bird
The MB unit you can use as is, a lot less work.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
4CamGT
4CamGT
A few more photos.
Nice to see my old 6 looking so good! Didn't know you had Harvey make you a set of 8R's for the rears. Nice touch. Thanks for posting Freeman.
1970 914-6 #2615 (Metallic Green) - SOLD 1974 911 US Carrera Coupe #63 (Lime Green) 1973 911 T Coupe #1891 (Gemini Blue) |
Wow, amazing look and solution.
'73 2.0 914 (2.8 /6 conversion in progress) '64 356SC '65 Ducati Falcon 80 ‘19 Audi SQ5 |
Wow! I haven't seen that car in over 20 years. Glad to see it's still running well.
I used that style lid cooler on my own 914/6 with multiple engines for decades. No cooling issues even on 100+ days blasting out to Vegas. ![]()
4CamGT
Henry, the main reason I changed it was I wanted a more hidden and discreet factory look. Fortunately Steve had the original uncut engine lid from the car with its original paint. Your solution was clever and effective. The two factory 930 coolers with fans it now has fits beautifully under the rear floor above the headers. It does a really good job of cooling. Not cheap though!! In the paperwork I got with the car was a receipt from you discussing it being dyno’d for around 6 hours before it being installed. The original Ebay ad mentioned 245hp. Might you still have the dyno sheet? Engine has never been opened up. It’s an 85 Carrera long block. It had 71K miles on it when you installed it. I estimate it has about 90K miles on it now. It doesn’t leak any oil. Starts on the button hot or cold!
4CamGT
![]() Here’s the original ad for the motor which was included in the paperwork file. Last edited by 4CamGT; 04-04-2025 at 07:46 PM.. |
Constitutional Liberal
As I understand Henry's conversion, there is zero modification to the original body and chassis. Zero modification if you source a different engine lid like stevesc_us apparently did.
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
4CamGT
I have a set of NOS factory GT flairs and I have a pair of stock factory rear fenders. So far I like the look as it is and it allows the 8R rear Fuchs. On the cooler install, they were installed without any cutting or holes added. We used existing bolts and studs by creating custom brackets. ![]() ![]() ![]() ![]() ![]() ![]() ![]()
I like the flairs and your car is beautiful. I saw it in Costa Mesa when the cooler was being installed. I did a similar flair on one of my 6s back in the late 70s so yes, flairs have been added to 914s for decades. I even like the add on passenger mirror.
It's your car and you can do whatever you want. It's just weird that you find a need to justify your decisions.
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell Last edited by Turbo_pro; 04-05-2025 at 09:46 AM.. |
4CamGT
