-   -   914-6 engine rebuild/upgrade options - opinions? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1082823-914-6-engine-rebuild-upgrade-options-opinions.html)
Neven911 01-08-2021 01:25 PM
Hi,
I have a 1970 matching # 914-6 I'm restoring and am at the engine rebuild stage, Over the years i've accumulated a few engine parts and would like more power than the 110Hp (When it last run the only mod was E cams). The use would be street only and I'd like it to run on 91 also I don't want to mod the 2R Case in any way that can't be reversed (bar internal changes) and it should to all intents and purposes look stock (hence using the webers) So I've considered the following options:
Option 1: Original 66mm non counter weighted crank, pauter rods and AA 86mm JE low Pomp P & C, 2.4 heads E cams, Webers
Option 2: Change to a 70.4mm crank, 2.4E Mahle 84mm P&C (which i have in my collection), Pauter rods, 2.4 Heads, E cams & Webers
The case I'd line bore, piston squirters, bypass mod, case savers (strangely already had IM bearings fitted)
Questions:
1. Has anyone got any feedback on the AA 86mm JE low Comp P&C set?
2. I have some 84mm Mahle Cylinders, would it be better to bore them to 86mm than use the AA provided ones?
Thanks for your input
Cheers Neven
911pcars 01-08-2021 02:52 PM
MHO. As you're aware, the 914-6 engine is a base 911T engine. Drop the engine and put it in storage. It'll cost more to bring it up to your/needed specs. Can repurpose the Webers for an upgraded engine.
Start with a better structure; stronger crankcase, large valve/port heads, etc. In the meantime, keep watch on the various classified ads.
Sherwood
Mark Henry 01-08-2021 10:43 PM
Agree, 2.0 to 3.6 all ballpark cost about the same to build, put the little T engine away on a skid.
I've got a 3.0 twin plug with Weber carbs, easy 250hp in my 914.
Henry Schmidt 01-09-2021 08:39 AM
Over the 25+years I owned a 914-6 street car, it got a new engine (saved the # matching) every time I needed money for the family vacation. 6-7 if memory serves.
I never felt the 3.0+ engine was what my car deserved.
It had a 2.4 S MFI, all sorts of 2.0, 2.2, 2.4 combinations. The most fun, easy to drive, octane safe engine was a 2.7 RS spec engine with Solex cams and 40mm Weber carbs.
A real 200hp, great torque and no detonation issues even without a front cooler.
2.7 cores a relatively inexpensive, rebuild costs are basically the same as the original engine and all the ancillary items, exhaust, flywheel, intake manifolds and sheet metal all transfer easily. Even the ignition harness and 3 pin CD are applicable.
colingreene 01-09-2021 11:20 AM
Id agree with henry on this one.
Especially since he had direct experience of it not needing a cooler.
He helped a friend with a 914 (Ethan) plan out the rebuild on his 914-6 motor I rode in it and the car is a complete blast.
That said i did once drive a 2.4E powered one and it was pretty good fun also.
targa72e 01-09-2021 11:34 AM
HI Neven,
I have a 914 that is a 6 conversion. The last engine I had in it was a 2.7 with RS pistons, Mod S cams and Webbers, very similar set up to Henry with a little more cam. It was a blast and I would highly recommend. I also have shorter 3rd and 4th gears, which are great for the street. The one issue with the 2.7 is it would get to 230deg on a 75 degree day driven easy. It really needed more cooling. I previously had a 2.4MFI E spec engine. That engine did not get as hot even on warmer days. As you plan your engine choices think about cooling needs. You probably don't want to cut a original 6 to put in a front cooler but you might look at options for a cooler in the rear.
john
Cairo94507 01-10-2021 10:26 AM
I have to agree with others here. Unless you are going to Concour your car and trailer it to shows, (in which case go with the stock 2.0 build) I would shoot for a 3.0 or 3.2. I did the 3.2 with 964 cams and SW chip and Ben McFarand's heat exchangers and muffler in my '71 914-6 and it just drives great. Plenty of power and torque. I opted to keep the Motronic injection and love it. No fuss, no fuel smell, reach into the car and turn the key and it fires right up. No changes to the chassis to accommodate the engine. I did add and external oil cooler up front to keep it cool in the summer in CA, but otherwise, no real issues.
Henry Schmidt 01-11-2021 10:53 AM
The challenges I see with 3.0 and larger engines in the 914-6 chassis is the extra torque on everything. Trans, axles, trailing arms etc.
There is also the challenge of ignition options (3 pin CD is not compatible).
Flywheel requires something special and the aluminum motors weigh more.
Larger engines generally generate more HP (cool) but now cooling becomes an issue.
All of these conversions are available but why open that can of worms.
2.4/2.7 bolt right in. No need to reinvent the wheel.
One though: at 145mph, the stock 914 chassis starts to dance. 200hp will get you there (been there, done that) so how much bigger should it be?SmileWavy
911pcars 01-11-2021 12:07 PM
The dancing (driving stress) can be reduced at 145mph or with torquer engines by reinforcing the chassis. There are chassis solutions available for quite some time. The stock chassis is fine for 4-cylinders and blvd. cruising; not so much after that.
Sherwood
targa72e 01-11-2021 01:15 PM
No doubt there are lots of solutions if you want to strengthen a 914 chassis. If this was a 6 conversion I would think it would be a no brainer. With a factory numbers matching 6 I think you might not want to be modifying too much.
john
Henry Schmidt 01-11-2021 03:10 PM
Sherwood
Actually, aero issues are the problem at that speed. Air under the nose, lift at the back as well as chassis flex. Of course there are wings, air dams and chassis stiffeners (I've done each extensively) but a stock 914-6 is collectible and demands a modicum of originality.
iamchappy 01-11-2021 07:13 PM
Then some of us do silly things to a 914 like this...Right Henry.
http://forums.pelicanparts.com/uploa...1610420647.JPG
http://forums.pelicanparts.com/uploa...1610420647.jpg
Neven911 01-12-2021 12:44 PM
Thanks Henry, you hit the nail on the head, FYI I have put in a chassis stiffening kit and the car is fitted with antiroll bars but my approach to keep close to the original, hence will probably go 2.2 and try and rebuild it to how I think Porsche should have in the first place (not crippled it to not compete with the 911T). I'm not aiming for a 145MPH racer otherwise I would have started with a 914/4
Cheers Neven
Henry Schmidt 01-13-2021 07:33 PM
Cheers Neven
Not a racer. Just needed to move it along. It was a stock 914-6 with a slight flare, 4) 7x15 Fuchs with 205x60 Pirelli P7 and a stock 2.4 S MFI engine. Gearing was modified but 30 years have done a number on my memory.
It was late Saturday afternoon, a friend burned a piston in a 356 during qualifying.
We located a new Shasta piston and my goal was to drive home, pickup a piston and get back in time to replace the piston, in the rain, groveling on the ground late into the night so the car could run on Sunday.
That drive saw the high speed run and the lane dancing at 145 mph. Scary but memorable.
123 mile each way in 2hr and 40 minutes.
The point is 180+ hp power is all the motor in a stock 914-6.
http://forums.pelicanparts.com/uploa...1610594393.png
gereed75 01-24-2021 07:24 PM
Neven, Nothing substantial to add here but my opinion- I have a stock bodied six with a 2.4 S built motor with Mod Solex cams. It is a very entertaining street car.
I have nothing against the bigger motors in 914’s and there is a lot of merit in the aluminum case 3.0 and bigger motors, but There is just something about the smaller motors that fit the spirit of the 914 in my opinion.
There is also merit in shelving the original motor, but if it were me, and your original cases are serviceable, I would build a short stroke 2.2 with The 2.4 heads and use Mod Solex cams with somewhere around 9.5 compression. Work with the Mahle jugs that you have. They can be bored and/ or Nikasil plated if necessary. Use the Mahle pistons if you can get them up towards the 9.5 CR. If not, go JE. All on the original cases with the machining mods you listed. Essentially your option 1 except keep you Mahles and go 9.5 and Mod Solex.
The fast Revving nature of these 66mm stroke motors coupled with the light weight chassis is just a sweet combination that channels the spirit of the 60’s factory race cars. The Mod Solex cams deliver really smooth torque as low as 2500 rpm with a real nice surge starting about 4500 rpm that continues building right up to 7400 rpm. Oh, and no additional oil cooling needed beyond the stock cooler and visually the whole thing is indiscernible from the original.
There is some resistance among the cognoscente about investing in mag case motors from the longevity standpoint, but in my view these cars are toys and probably won’t see 40,000 miles in our lifetimes. No reason that a sound, well built mag 180 hp motor won’t provide at least that much reliable service.
Any questions on how to do this right, just ask Henry for help. He has a soft spot in his heart for these cars ( and a shop full of all the right trick early 911 stuff) and he will do whatever he can to help.
One other recommendation- Install a side shift trans with a shifter kit from tangerine racing. 901’s can actually shift really nicely (once out of first) and this completes the driving experience in these cars - big fun!
JmuRiz 01-25-2021 08:32 PM
Henry, I know you did this setup on a 3.0 a while back...would this work with a GT engine lid? I’m looking for ideas on my future 2.7 similar to your specs listed in post #4
http://forums.pelicanparts.com/911-engine-rebuilding-forum/419698-front-oil-cooler-pressure-side-not.html#post4059220
http://forums.pelicanparts.com/uploa...1611635532.jpg
Henry Schmidt 01-26-2021 08:58 AM
More air is always better. We used the small hole technique in an attempt to direct suction from the fan through the cooler.
I used this same technique on my street six but I did notice higher engine tempts on hot days at idle. Full throttle and cruise the cooler worked but sitting still was a challenge.
JmuRiz 01-26-2021 10:17 AM
Good info, thanks.
I'll probably try under the rear trunk first and see how it works, can always move it if needed. I have a large Setrab with dual Spal fans I'll put on a thermo switch.
Mark Henry 01-26-2021 12:23 PM
That looks like a RX7 cooler which has been a common choice for a 914 front cooler. Now the cooler of choice for the lower budget crowd is the MB oil cooler which is just a little bit smaller but easier to connect. The RX7 had smaller connector bungs that many weld and make bigger, the MB cooler already has bigger metric threaded bungs.
You could use either one for Henry's trick, but the MB cooler gives you something easier to install in the lid or one day in the front of your 914.
Henry Schmidt 01-26-2021 12:47 PM
We used the RX7 cooler because we liked the idea of a built in thermostat.
911pcars 01-26-2021 02:18 PM
Hmm. That seems like the same issue as a Kool-Collar install; an "oil cooler" product sandwiched around the engine oil filter.
The air path for absorbed and rejected heat from these coolers is directed into the air cooling stream instead of dumping heated air outside the vehicle. This raises the temperature of the ambient temperature air flow, not ideal.
Sherwood
Henry Schmidt 01-27-2021 07:07 AM
Sherwood
You are correct..It's not the best option especially if you spend a great deal of time sitting in traffic. But if you keep it moving this set uo does reduce engine oil temperatures which does most of the cooling in a 911 engine.
911pcars 01-27-2021 08:20 AM
Henry, understood and acknowledged. It’s also a major project to install a front cooler with its plumbing in the tight space constraints.
mepstein 01-27-2021 05:32 PM
Originally Posted by 911pcars (Post 11199688)
Henry, understood and acknowledged. It’s also also a major project to install a front cooler with its plumbing in the tight space constraints.
We make some replica GT hard lines and some other 914-6 conversion parts that make it easier. It's not usually space constraints but the cost that holds people back. Unfortunately, theres no getting around the fact that quality parts and labor cost money. 914-6Werkshop dot com
http://forums.pelicanparts.com/uploa...1611797550.png
Cairo94507 01-30-2021 07:55 AM
mepstein hits the bullseye as expected. If you are going to add an oil cooler to a 914, do it the way the factory did. This is the way I did mine along with the PMS oil cooler and thermostat. The car never overheats and I am running a 3.2 in the CA Bay Area where we see 105 degrees in the summer with lots of traffic.
gereed75 02-02-2021 10:09 AM
Henry,
So the Rx 7 cooler has a built in TStat? Any reason this would not work plumbed in to the scavenge side of the original oil system?
Seems that would be a most simple system. Scavenge outlet plumbed into this cooler with built in thermostat controlling flow to the cooler.
Agreed that this cooler location is not optimal, but my gut instinct engineering feel is that increases in charge temp would be small and oil cooling effective.
Henry Schmidt 02-02-2021 10:56 AM
Originally Posted by gereed75 (Post 11208191)
Henry,
The oil filter is fed from the scavenge side of the oiling system. Pulling it off a sandwich plate under the filter is essentially what the GT cars did. They just build a sandwich plate and thermostat into the filter housing.
By using a sandwich plate as I described, the entire project is a bolt on accessory.
Modifying the deck lid is the only permanent alteration. That's why sourcing another deck lid makes sense. Paint it to match, save the original and you win.
The 914-6 is climbing in value.....mess with it at the cost of originality and resale value.
911pcars 02-02-2021 12:57 PM
For a full flow cooler, the inlet and outlet ports are typically replaced by larger weld-on adapters (e.g. AN-12, -16).
Mark Henry 02-02-2021 01:21 PM
^ this with the Rx7 cooler, the ports are a bit on the small side. Also many cut one or both ends off, then welded plates onto the end, made a matching plate to bolt on that has the fitting. They can then unbolt the plate for cleaning the cooler. This mod deletes the RX7 thermostat, you use an external t-stat.
The MB unit you can use as is, a lot less work.
4CamGT 03-31-2025 06:09 PM
This is my 914-6. I bought it from the previous owner who had the 3.2 installed with the RX7 cooler. It ran great but aesthetically I wanted it to look stock factory Porsche. I worked with Ed Palmer at KundenSport. Fortunately I got the uncut original engine lid. We installed the original 914-6 fan shroud and air box and got rid of all the non-stock looking parts. We then installed two new 930 coolers w/fans below the rear floor w/o cutting or drilling by using existing mount locations using fabricated brackets etc. I had Harvey Weidman make a pair of R7’s (w/205/55R15) for the front and non-existent R8’s (w/225/50R15) for the rear. We dialed in the gearbox with new bushings. My 6 now runs all day long at 180 to 200 degrees, shifts and drives amazing. The original #’s matching motor is stored safely in a crate. Not criticizing any of the previous work as it gave us a head start and a good core to improve on.
http://forums.pelicanparts.com/uploa...1743468989.jpg
4CamGT 03-31-2025 06:12 PM
A few more photos.
http://forums.pelicanparts.com/uploa...1743469875.jpg
stevesc_us 04-01-2025 02:57 PM
Nice to see my old 6 looking so good! Didn't know you had Harvey make you a set of 8R's for the rears. Nice touch. Thanks for posting Freeman.
JmuRiz 04-01-2025 07:42 PM
Wow, amazing look and solution.
Henry Schmidt 04-02-2025 09:15 AM
Wow! I haven't seen that car in over 20 years. Glad to see it's still running well.
I used that style lid cooler on my own 914/6 with multiple engines for decades. No cooling issues even on 100+ days blasting out to Vegas.
http://forums.pelicanparts.com/uploa...1743610267.jpg
http://forums.pelicanparts.com/uploa...1743610267.JPG
4CamGT 04-04-2025 05:35 PM
Henry, the main reason I changed it was I wanted a more hidden and discreet factory look. Fortunately Steve had the original uncut engine lid from the car with its original paint. Your solution was clever and effective. The two factory 930 coolers with fans it now has fits beautifully under the rear floor above the headers. It does a really good job of cooling. Not cheap though!! In the paperwork I got with the car was a receipt from you discussing it being dyno’d for around 6 hours before it being installed. The original Ebay ad mentioned 245hp. Might you still have the dyno sheet? Engine has never been opened up. It’s an 85 Carrera long block. It had 71K miles on it when you installed it. I estimate it has about 90K miles on it now. It doesn’t leak any oil. Starts on the button hot or cold!
4CamGT 04-04-2025 06:28 PM
Originally Posted by 4CamGT (Post 12441195)
Henry, the main reason I changed it was I wanted a more hidden and discreet factory look. Fortunately Steve had the original uncut engine lid from the car with its original paint. Your solution was clever and effective. The two factory 930 coolers with fans it now has fits beautifully under the rear floor above the headers. It does a really good job of cooling. Not cheap though!! In the paperwork I got with the car was a receipt from you discussing it being dyno’d for around 6 hours before it was installed. The original Ebay ad mentioned 245hp. Might you still have the dyno sheet? Engine has never been opened up. It’s an 85 Carrera long block. It had 71K miles on it when you installed it. I estimate it has about 90K miles on it now. It doesn’t leak any oil. Starts on the button hot or cold!
http://forums.pelicanparts.com/uploa...1743816418.jpg
Here’s the original ad for the motor which was included in the paperwork file.
Turbo_pro 04-05-2025 06:58 AM
Henry, the main reason I changed it was I wanted a more hidden and discreet factory look. .....edit.....
This seems a little odd. Obviously the rear flairs are more detrimental to the "factory look" than a completely and easily removed deck lid.
As I understand Henry's conversion, there is zero modification to the original body and chassis. Zero modification if you source a different engine lid like stevesc_us apparently did.
4CamGT 04-05-2025 07:41 AM
The rear flairs apparently have been on the car since it was almost new. There’s no evidence of them being added or welded on as the original undercoat is undisturbed. As I was curious about their origins, I went to visit the Porsche Museum some years ago. I was given personal access to the Piech 914-8. They graciously allowed me to take templates off of the rear flairs to compare with mine. They’re the same. Also of interest are the flairs on the 914-6GT prototype. Also similar. The most plausible scenario is they were modified in the early 70’s in the Bay Area where my 6 lived.
I have a set of NOS factory GT flairs and I have a pair of stock factory rear fenders. So far I like the look as it is and it allows the 8R rear Fuchs.
On the cooler install, they were installed without any cutting or holes added. We used existing bolts and studs by creating custom brackets.
http://forums.pelicanparts.com/uploa...1743863994.jpg
Turbo_pro 04-05-2025 09:43 AM
I like the flairs and your car is beautiful. I saw it in Costa Mesa when the cooler was being installed. I did a similar flair on one of my 6s back in the late 70s so yes, flairs have been added to 914s for decades. I even like the add on passenger mirror.
It's your car and you can do whatever you want. It's just weird that you find a need to justify your decisions.
4CamGT 04-05-2025 09:54 AM
Cooler was installed by Ed Palmer at KundenSport in Oxnard (now in Santa Paula). BTW, just sharing the journey. I did a lot of online searching for successful rear cooler solutions for the 914-6 with few results. I’m putting this here to hopefully help the next enthusiast.
