1979 930 @outlaw3.4
MZ3 SBC's Avatar
Pulling Scavenge Pump Pulley
I searched and came up bust: anybody know why/ how to remove the pulley ? It has 2 5mm Allen heads holding pulley to CAM. Before I strip it.....
Checking to see if the cam is inscribed ....maybe !! ?
Car is 79 939
1979 930 3.4l Peter Dawe Motor, Bosch Twin Plug, Dual Bosch CDI, J&S Ignition Control, Webcam 158 , Maxed Flowtech Fuel Head, BL Adj WUR, Braided Fuel Lines, 009 Injectors, GT35R, TIAL .7with Turbosmart MBC, Fabspeed Long Neck IC, Fabspeed Headers, GT3 Style Pipe off turbo, Rennshift Short Shift, KEP Clutch Package, 8.41, Elephant Racing Suspension, Weltmeister Sway Bars, ??WHP, Innovate MTS Gauges, RPM, Switch,SplitSecondAIC 7th
Old 01-22-2021, 05:23 PM
You mean the bolts feel like they'll strip at the allen wrench part?
Use vice grips on the outside of the bolt while using your allen wrench at the same time. Replace the bolts when you get them out.
Old 01-22-2021, 06:40 PM
1979 930 @outlaw3.4
MZ3 SBC's Avatar
Good advice. Thanks
Old 01-22-2021, 09:56 PM
1979 930 @outlaw3.4
MZ3 SBC's Avatar
Worked like a charm....talk about missing the obvious!
The Cam was a big W on the butt and what looks like 1 5 8 stamped into it..
There is a Webcam 158....could be what this is
Old 01-23-2021, 04:27 PM
That's probably exactly what it is. SC cams, IIRC. Good upgrade for a 930.
Old 01-23-2021, 05:21 PM
1979 930 @outlaw3.4
MZ3 SBC's Avatar
Thanks- seems to be. Its not easy to see if it says 158 with a tiny number 8 or if it says 15 and its a o for degrees....i am going with 158
Webcam has a few 158 grinds.....and DC Cams has a DC 15 which is and Sport SC ..
either way I think I am close.
Old 01-27-2021, 08:37 AM
1979 930 @outlaw3.4
MZ3 SBC's Avatar
Webcam 158
Old 01-27-2021, 08:44 AM
